Old 03-27-2009, 01:20 AM   #10
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Ok, I just spent a half hour on the phone with dyno guy. He does not recommend that I start with larger injectors or more powerful fuel pump. He recommends a boost-sensitive adjustable fuel pressure regulator.
Thanks to CTScott, I found the OEM fuel pressure regulator. It is not in a place that is easily replaced by an aftermarket unit. Since the fuel system's pressure is now maxed out at the 44.1 to 49.7 psi put out by the OEM regulator, using another regulator after this unit to get higher pressure is impossible.
Dyno guy now admits that replacement of the fuel pump (like Garm's turbo install) or replacement of the stock injectors is probably in order if the goal is to get more fuel to the engine during boost.
Calculating the proper injectors size, using the many online injector calculators, is a little bit daunting but I'll use them all until I can understand the concept and get consistent results.
I'd rather understand the science behind the proper selection of injectors rather than just shotgunning any device in and hoping that they do the job adequately.
AFR running extra rich at WOT? eTiMaGo Performance Modifications 15 03-10-2007 11:10 AM
