#37 | |
![]() ![]() Drives: Yaris 5 door Liftback Join Date: Oct 2008
#38 |
OK, I want some decent, cheap, direct fit, plug-and-play speaker replacements in my 08 LB, both front and back but mainly the front...any recommendations?
Cheers! M2 |
#39 |
okay, i'm looking to make my system pound in this car. want deep base and good quality. i have installed systems in my dad and i know what im doing, never on my own car, it has to be perfect. lol. here is the catch....its 2010 rs hatch and i want the trunk still....any ideas without using a box? i was thinking putting a 14inch and take out the spare tire....thoughts? also i have never used a stock deck to power a system. can the stock yaris deck be used?
#40 |
Drives: yaris 2010 sport Join Date: Dec 2009
the front speaker size is 6 1/2"
Do I have to care about the depth? and what is the depth ? |
#41 |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
2" someone said. I'm planning on using a 1" spacer, hope that will fit with the plastic panel.
#42 |
STICKY
#43 |
![]() Drives: toyota yaris 2007 sol d4d 5p Join Date: Mar 2010
excuse me for my english. i like to know how i change radio in my carf toyoyta yaris sol d4d year2007.
#44 |
excuse me for my english. i like to know how i change radio in my car toyota yaris sol d4d year 2007.
#45 | |
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options Join Date: Feb 2010
I wuld like to do this too!
![]() BUMP!
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
#46 |
Ideally... For me I took out first the OEM speakers to have the actual size of them as sample. You can bring one or two as like and have them match for your replacements, with this you can actually see the difference and decide which or which not FITS. Besides, you would still take out the OEM spkrs for replacements, why not bring them.
Just an idea anyway. |
#47 |
![]() ![]() Drives: 3dr Lftback (meteorite) Manual Join Date: Apr 2010
yaris2010RS,
You will be looking at some fun custom work. You can use the stock HU but you will need to run that signal to, ideally, a 4 channel amp that will run your front and back speaks. Then you will want to run a monoblock amp to your sub. The trickiest part will be matching up all the wires coming out of the stock HU. It will just take some time. Aftermarket HU's are built to just plug and play. you just run RCA cables to your amps. If you go with the two amps, you will need to find places to mount both of them and your sub. And if you want it to really thump your will want to look for a place to install a capacitor also. You may have run into capacitors on past installs with your dad. If not, so you know, it will help your system to have all necessary power it needs for optimal sound output right when it needs it. it will do this without placing unnecessary strain on your battery. If you are really looking for a system that "pounds" those pieces are a minimum. And use a set of component speakers up front. You will not regret using this setup. Last edited by DailyDriver; 04-28-2010 at 11:05 AM. |
#48 |
Roadrunner Jr.
I'm going to disagree with Daily Driver...a cap is not a necessity. Caps do NOT provide power, they store it. Now, if you want POWER, get aftermarket alternator from one of several manufacturers. Mechman, Ohio Generator, Iraggi, Powerbastards...
Also, do the Big 3 upgrade first before making any hasty decisions. There is also more specifics to uncover about just slapping amps in. Some amplifiers that you might want to use might not have line level inputs. In that case you're going to need a Line Output Converter. There are many out there from the $20 all the way up to the $1000 range. Within the same subject for this thread, here's two videos of the integrated radio being removed and an aftermarket wiring harness being prepped: http://www.youtube.com/watch?v=7N2Y5YIdoL8 http://www.youtube.com/watch?v=xySrP...eature=related
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 05-01-2010 at 09:16 AM. |
#49 |
Roadrunner Jr.
Here's a couple pictures of what the BEST kit (Ai) looks like with and without a radio in it:
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#50 | |
sq that HU is SICK!
#51 | |
![]() Drives: 2008 Polar White Yaris Sedan Join Date: Mar 2010
the silverish part surrounding your best kit, is that the piece that comes with the car or did you have to buy that? i ask because i look closely at mine all the time and it does not look like it can be separated from the part that houses the heat/ac dials. further, the stock stereo doesnt look like it can be taken out |
#52 |
Roadrunner Jr.
You probably have an integrated unit...which mine came with as well. I simply purchased a Toyota double DIN bezel and used an aftermarket 1 DIN kit. I took it a little farther than most though by sealing up the annoying pocket and color matching it to the car.
#53 |
ah a bezel. thank you. so with integrated unit, that part is seperate from the bottom part with the AC controls?
#54 |
I'm buying an '11 yaris sedan tomorrow, but I still have my system from the '01 mazda protege I sold. I love my boston acoustic speakers, and my back 6x9's will fit, but is there anyway my front 4x6's will fit? I would prefer not to buy new speakers if I don't have to. If this is answered elsewhere, first post, joined today, sorry.
| aftermarket stereo kit? | xCookiE | General Yaris / Vitz Discussion | 4 | 02-16-2006 10:33 PM |
