Old 08-25-2006, 05:45 PM   #1
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Aftermarket Stereo / Speaker Specifications
TO Admins: Please Sticky this Post
I thought it would be a good idea to post + sticky this thread for quick reference for those who wish to install aftermarket stereos, speakers, and anything else that may come up as a FAQ.
If there is any information that is incorrect, please feel free to correct me. Any additions are just as welcome so we can make this thread the ultimate reference for stereo info for the Yaris.
Dash Kits - Single Din / ISO Mount
Metra 99-8216
American International TOY K969
Dash Kits - Double Din / ISO Mount
Metra 95-8202
Harnesses - Plugs Directly into Vehicle Plug (for aftermarket stereo)
Metra 70-1761
Best Kit BHA1761
Scosche TA02B
Speaker Sizes - Hatchback 3DR/5DR
Front L+R 6.5"
Rear L+R 5.25"
Speaker Sizes - Sedan
Front L+R 6.5"
Rear L+R 6" x 9"
Speaker Spacers/Brackets for Oversized Speakers (ie. Components, Midwoofers, etc)
For those of you installing larger speakers with big magnets, you may want to use spacers to allow your speakers to be mounted to the door.
I've created a template for the spacer for the hatchback speaker locations found here: http://www.yarisworld.com/forums/showthread.php?t=1930
At minimum you should use 1/2" MDF for appropriate clearance for the magnet when your window is completely down.
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 08-25-2006, 05:51 PM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Hey big sky
"Speaker Sizes - Hatchback 3DR/5DR
Front L+R 6.5"
Rear L+R 5.25"
Do you know whats the best "Scosche" bracket / spacer to use onto the rear of the yaris liftback???
I was thinking of getting
http://www.scosche.com/scosche_carau...48&ItemID=SAT6
cuz thats for the "2000-Up Toyota Echo / Avalon"
Old 08-25-2006, 05:54 PM   #3
bigsky2
Cousin Vitz
bigsky2's Avatar
hasher,
I am afraid I do not have an answer for you.
I have not replaced the front/rear speakers so I can't answer you!
From what I've read, it's possible to use the existing bracket/spacer because the (stock) rear speaker size is a little larger than 5.25".
Old 08-25-2006, 05:56 PM   #4
hasher22
Look mum no stars!!
hasher22's Avatar
Originally Posted by bigsky2
hasher,
haha thats ok, i baught 6.5 inch speakers for the rear of my yaris....
but the stocked brackets are too small (the rear ones).....so i need to buy some brackets that will acually meet the holes so i can screw it in. (I dont wanna rivet it in)
I baught MDF Wood 6.5 Inch speaker brackets.......the 6.5 inch speakers fit well on the MDF Wood brackets, but its not big enough to meet the 3 rivet holes in the rear. ARRG!!
Old 08-25-2006, 11:27 PM   #5
johnnyfive
johnnyfive's Avatar
this is a good idea to sticky this, wish i would have seen this before i went to the local shop today to get the dash kit.
i knew they wouldnt have it in stock, but figured they could order it, they check thier local distro. and didnt have any. so he got on the phone with Metra directly in florida, and they only said they had the Double din kit, i asked about a pouch/blank for it...but said it was just a double din...wish i would have jsut had the part number for them...gues ill have to go back there tomorrow and give it to them....
Old 08-26-2006, 11:42 AM   #6
ChinoCharles
Drives: LB
STICKY
Old 08-26-2006, 05:24 PM   #7
Lowfront
Drives: Yaris Sedan
I want to get 6.5 rounds in the rear of my sadan....
So no solution yet?
Lowfront is offline   Reply With Quote
Old 08-26-2006, 07:19 PM   #8
hasher22
Look mum no stars!!
hasher22's Avatar
So no solution yet?
seriously if u want better sound / bass replace the 6x9's to new 6x9's......
Old 08-26-2006, 08:41 PM   #9
johnnyfive
johnnyfive's Avatar
So no solution yet?
there is a solution, cut an adapter out of MDF, and there you go :)
outside should fit the stock location, and the inside should fit your new speakers.
but to fit "bigger" speakers in the location 6.5 > 6 you may need to do some cutting to the rear deck, or do some creative tapering on your MDF ring
Old 08-28-2006, 04:10 PM   #10
Lowfront
Drives: Yaris Sedan
http://www.scosche.com/scosche_carau...48&ItemID=SA69
think this will work?
Old 08-29-2006, 01:08 AM   #11
johnnyfive
johnnyfive's Avatar
that will work, but it is likley for 5.5's, not 6.5's, i didnt see any specs on the inside hole...
Old 08-29-2006, 05:42 AM   #12
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
From a physics standpoint, a 6.5" can be engineered to sound better than a 6x9 ever can.
Old 09-12-2006, 03:03 AM   #13
johnnyfive
johnnyfive's Avatar
sticky!
Old 09-13-2006, 03:43 PM   #14
ebowers83
ebowers83's Avatar
Drives: 2007 Yaris 4D Sedan
What is the difference between single din and double din for a head unit mounting kit?
ebowers83 is offline   Reply With Quote
Old 09-13-2006, 03:49 PM   #15
ebowers83
ebowers83's Avatar
Ok so I figured out the difference. If I obtain one of these kits, realistically, how hard is it to replace? Will I need any other parts? How long will it take for an amateur?
Old 09-14-2006, 10:54 PM   #16
johnnyfive
johnnyfive's Avatar
fairly easy to change out head unit, the hardist part is the wiring
just carefully match up all the wires on the harnes packaging, and in your aftermarket headunit manual.
Old 10-12-2006, 06:58 AM   #17
hasher22
Look mum no stars!!
hasher22's Avatar
Warning - SAT6 SPACER/BRACKETS WILL NOT FIT INTO YOUR REAR LIFTBACK SPACE.
Thankyou :) How do i know? Cuz i tried.
Old 10-12-2006, 02:51 PM   #18
bigsky2
Cousin Vitz
bigsky2's Avatar
The Sat6 is primarily for 6.5" speakers aren't they?
Well you hav spacer templates, so go make some!
aftermarket stereo kit? xCookiE General Yaris / Vitz Discussion 4 02-16-2006 10:33 PM
