#55 | |
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#56 |
Ill need to pull my wheel off for some measurements, but im pretty sure I can design it. Do you have a link to another kind that you want to look the same just to make sure I have the right piece in mind?
#57 |
nipple
#58 |
Bathroom + Laptop = <3
hahahah I LOL'ed I knew someone was gonna bring it up again
#59 | |
#60 |
Ohh you just want a straight spacer, I was thinking adapter plate, yeah thats no problem at all, Ill get those measurements when I do my brakes this weekend. I assume you want them to fit a stock wheel
#61 |
Make like a 5 MM something thats thin enough to bring the rear wheels out a bit but without requiring to replace the studs.
#62 |
yeah i was about to chime in, the studs would be an issue if you go to large on the spacer. But also an adapter would be nice too for more exotic wheels if anyones into that kind of stuff..
#63 |
Well, I'd rather go for the adapter for a reasonable price. I have 15x6.5" ET +38 wheels BTW.
#64 |
So it should be fine if I modeled it on the stock wheel
#65 |
This would be a cheaper alternative to the H&R spacers I carry. (They do come with adjusted length studs, though).
#66 |
I dont know if I would trust myself designing an adapter, so maybe a 5 or 10 max mm straight spacer from me/nexus
#67 |
Yeah those spacers sound good to me. I'm looking for 10mm though. 5mm just doesn't seem wide enough for the rear in my case.
Can you get the longer studs as a package deal? That would sure be helpful.
#68 |
I dont know that i will be able to source longer studs better than garm or another vendor.
They already have their connections |
#69 |
Got the spacers, one is our proto, 3 are too small for the fogger, so they can be sold as is for spacers, they look decent, cut from stainless
#70 |
#71 |
I'll need to get the exact thicknesses for you before I sell them so you know which length bolts to get to replace the 1 bolt that is inverted on the manifold. I just know that the one we're using is 1/2"
#72 |
![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
In theory, a throttle body spacer, what performance increase does it provide?
| 1ZZ Throttle Body Spacer | tk-421 | Performance Modifications | 34 | 07-11-2017 09:48 PM |
| Spacer Template for Hatchback Aftermarket Speaker Install | bigsky2 | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 03-12-2014 01:53 PM |
| Ideal Spacer Width For the Rear? | tk-421 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 01-27-2009 05:59 PM |
| DIY Spacer Templates for Speakers - Hatchback | bigsky2 | DIY / Maintenance / Service | 9 | 09-22-2007 06:16 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
