Old 09-24-2006, 10:24 PM   #1
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
DIY Spacer Templates for Speakers - Hatchback
Thought I'd post it in this section as well since it's a DIY task.
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 10-10-2006, 11:54 PM   #2
Yaris PTY-507
SUPER YARIS FASHION
Yaris PTY-507's Avatar
Drives: 2005 Yaris HB Super Red
THIS IS ONLY FOR 2006-2007 HB?
OR ALSO FOR MODELO 2005?
Yaris PTY-507 is offline   Reply With Quote
Old 10-11-2006, 12:01 AM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
Dumb question... but why would someone need these?
Old 10-11-2006, 12:47 AM   #4
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
To make custom brackets....
im using the 5.25 template
Old 10-11-2006, 12:57 AM   #5
Black Yaris
der Zeck
again I ask.... why would someone need custom brackets?
Old 10-11-2006, 01:08 AM   #6
hasher22
Look mum no stars!!
hasher22's Avatar
Ok, lets put it this way, i baught 6.5" speakers for the back, NOT KNOWING that the bracket and size of the rear is 5"25". I cannot find any 5"25 spacers/brakets that will fit in the rear. So i have to make my own.
Old 10-11-2006, 02:47 AM   #7
bigsky2
Cousin Vitz
bigsky2's Avatar
You need these because if you decide to replace your stock speakers, you won't have any bracket/spacers to use with your aftermarket speaker unless it comes with one. Most aftermarket speakers do not come with brackets because the screw holes are all different among all the car manufacturers.
Car speakers are mounted in one of the following ways:
Door Metal - Bracket - Speaker
Door Metal - Speaker/Bracket
The Toyota OEM speakers have the bracket mounted right into them. The speaker and bracket are integrated as one piece, and if you remove the OEM speaker all you have is a very large hole in the metal and your speaker will not fit. You can perform a hack job of sorts by destroying (gutting) the speaker from the bracket assembly and then mounting your aftermarket speaker into what's left of the OEM speaker/bracket assembly. But I don't suggest this unless you are planning to trash the OEM speakers anyway.
You will also need this if you ever install medium to high end speakers because med-high end speakers have larger mounting depths and bigger magnets which will definitely make contact with your window, metal or any other object if it is not properly raised with a spacer.
Custom spacers/brackets also help with sound dampening as it ensures that your speaker is sitting flush and flat against the spacer, and if done correctly, your spacer should also sit flush and flat with the door's metal. You want to reduce any amount of "dead air" between the speaker, bracket, and metal for the best sound reproduction.
Old 09-22-2007, 10:37 AM   #8
skateboarddziner
Just driving
Drives: 07 Toyota Yaris sedan
can anyone help me with templates for 07 yari sedan???
thanks in advance...
skateboarddziner is offline   Reply With Quote
Old 09-22-2007, 04:07 PM   #9
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Nice job! Almost a year ago I wanted to replace the stock speakers but didn't because of this reason. I have since seen brackets available from crutchfield but have yet to upgrade my speakers. Maybe now I'll use this DIY and save some money.
Old 09-22-2007, 06:16 PM   #10
KSIbucky
KSIbucky's Avatar
i would just have someone else install it i hate having other people work on my car but if they mess up they pay for it not me
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
