Old 04-23-2009, 12:01 PM   #127
MGargano
Drives: 2009 Yaris Hatchback
Originally Posted by mikenacarato View Post
i just want to stress a point again. anyone who just did this mod you have to drive it for a good 2 days or so for the ecu to learn the now tb. it will oscillate bad until then.
Oh I was under the impression that the chip swap made the oscillation and CEL go away immediately. Think I should leave it on for a few days?
MGargano is offline   Reply With Quote
Old 04-23-2009, 12:48 PM   #128
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i guess time will tell
Old 04-23-2009, 01:12 PM   #129
jkuchta
Drives: 2007 Yaris hatch (red)
Yes....I would leave it on and see what happens.
jkuchta is offline   Reply With Quote
Old 04-23-2009, 02:38 PM   #130
MGargano
Originally Posted by yarstar View Post
That worked for me. You may be getting ocillation due to an air leak. Make sure you did the gasket maker correctly and really let it set up a long time (I let mine set up overnight). Check also the intake for leaks.
I pulled mine back off, waited a week, did the chip swap again, and re-installed and have had no probs since.
Did you get CEL and oscillation the first time you did the chip swap?
Old 04-23-2009, 03:23 PM   #131
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i did after the chip swap for a day or so. give it some time.
mikenacarato is offline   Reply With Quote
Old 04-23-2009, 05:54 PM   #132
MGargano
I'm gonna leave the stock one on for a week or so and then start over with the chip swap. Glad to hear I wasn't the only one having this problem.
Old 04-23-2009, 07:33 PM   #133
mikenacarato
SIPNDEW
Drives: 15 STI
:) mine still cold idles high for a min but it goes down to normal after that
Old 04-23-2009, 08:08 PM   #134
severous01
ok.......
here's the deal....again...for you who will listen now
you can stop the oscillation in less than ten minutes.
after the swap, pull the plug on the battery, drain caps by hitting brakes and turning on lights
plug in batt
start car AND LET IDLE FOR 10 MINUTES
you have to re-learn the iac sensor to the new throttle body...it is oscilating to learn the position of the iac motor....unless you have a vac leak somewhere.
Old 04-23-2009, 08:35 PM   #135
MGargano
Originally Posted by severous01 View Post
ok.......
plug in batt
Yeah I did that... didn't help at all. I disconnected and drained the battery before I even removed the TB.
Old 04-24-2009, 07:56 AM   #136
bxrich
bx in the house
Drives: toyota yaris sedan
quick ? guys what's the diameter on the 1zz tb is it 2" & half or 3"
bxrich is offline   Reply With Quote
Old 04-24-2009, 07:59 AM   #137
yarstar
Drives: 2008 Absolute Red HB
Mine's on the car, so I can't really measure it right now.
Do a search. It's on here. I think in the Performance Mod section. There's a picture of both TBs and the exact measurement of each.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 04-24-2009, 08:35 AM   #138
bxrich
bx in the house
will do thanks
Old 04-24-2009, 12:43 PM   #139
marcus
toyota
marcus's Avatar
been 2 days anyone got rid of the issue..
Old 04-24-2009, 12:52 PM   #140
jkuchta
I never had the issue.
I think you have an air leak somewhere in the system. Best bet is to pull the TB, and reapply the sealer and let it sit overnight to set up.
Old 04-24-2009, 01:13 PM   #141
MGargano
Reinstalled the 1ZZ w/ chip swap this morning with gasket sealer and coolant bypass but didn't disconnect the battery so we'll see if anything changes later today.
Old 04-26-2009, 02:24 PM   #142
marcus
toyota
marcus's Avatar
well................anyone.
Old 04-26-2009, 07:16 PM   #143
MGargano
Good so far. Got oscillation on the first & second cold start but so far I'm 2 days oscillation free. I got a CEL today but took care of it with the Scangauge. I'm just glad the oscillation's gone.
Old 04-26-2009, 09:33 PM   #144
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Can't wait to get my TB in the mail
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
