Old 04-26-2009, 08:16 PM   #145
MGargano
Drives: 2009 Yaris Hatchback
Good so far. Got oscillation on the first & second cold start but so far I'm 2 days oscillation free. I got a CEL today but took care of it with the Scangauge. I'm just glad the oscillation's gone.
MGargano is offline   Reply With Quote
Old 04-26-2009, 10:33 PM   #146
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Can't wait to get my TB in the mail
Old 04-27-2009, 11:37 AM   #147
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
my CEL kicked off today so we'll see how long that lasts for
http://www.4055design.com
Old 04-27-2009, 06:23 PM   #148
MGargano
Mine came on this morning too... got minor oscillation at cold start this morning also but nothing major.
Old 04-29-2009, 03:08 PM   #149
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
bump for update...
Old 04-29-2009, 03:55 PM   #150
jkuchta
Drives: 2007 Yaris hatch (red)
MGragano, What is the code for the CEL? Have you adjusted the idle set screw yet?
jkuchta is offline   Reply With Quote
Old 04-29-2009, 05:43 PM   #151
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
9 PAGES and i still see a CEL.......
Old 04-29-2009, 06:15 PM   #152
MGargano
P0505- Idle Malfunction. No, I haven't adjusted the idle screw.
Old 04-29-2009, 07:41 PM   #153
jkuchta
That's why you get a CEL. You MUST adjust the idle to get rid of that CEL, as it's a result of the ECU having to over-adjust to hit a target idle RPM. Re-read thread #78, and you will more than likely get rid of the CEL for good.
Old 04-29-2009, 10:32 PM   #154
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
no you dont. i didnt touch my idle screw, its still covered in the hard crap. all i did was the chip swap, nothing else.
mikenacarato is offline   Reply With Quote
Old 05-02-2009, 05:11 PM   #155
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Cool thanks for the diy.
I got my 1zz tb from crxgames. I removed the rivets, swapped the chips, screwed them on, and added some rvt gasket maker. Plugged in the new 1zz tb with the 1nz chip and started her up. This was after I had disconnected the battery for an hour. So it started to oscilate from 2-3k like many others have mentioned. I waited for exactly 10 minutes and it ended up idling at around the same rpms as the stock tb. Drove around a bit and no cel. I didnt mess with the idle screw cause the idle was just fine. I had to run some errands and every time I started up my car no problems or cel. I have yet to start my car during a cold start up so I'll chime back in here with results. The ecu hasnt learned the changes completely yet, my auto keeps shifting too early still. I can tell theres gonna be a ton of power over 3k. I'm not sure thought, but i think i'm feeling a lot of increase in low end...@_@
Getting some headers worked on right now, should compliment the TB very well.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-02-2009, 05:22 PM   #156
jkuchta
Mike, Mgargano's specific CEL is more than likely caused by the idle screw not being adjusted.
Old 05-02-2009, 05:28 PM   #157
right -- read the whole sentence above, it's to get rid of a CEL. If you didn't get a CEL, you don't have to adjust it.
Old 05-02-2009, 05:43 PM   #158
eii
Rides canyon walls
eii's Avatar
Originally Posted by bxrich View Post
quick ? guys what's the diameter on the 1zz tb is it 2" & half or 3"
stock yaris 1nz tb is 2"
1zz tb is 2.5"
Old 05-03-2009, 02:50 AM   #159
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
1zz tb is 2.5"
i think 1nz tb is 2.25"
no?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Old 05-03-2009, 10:16 AM   #160
marcus
toyota
marcus's Avatar
bumpin..
Old 05-04-2009, 06:39 PM   #161
eii
Rides canyon walls
eii's Avatar
no?
Pic of my 1nz tb now a paper weight on my desk <3
Old 05-06-2009, 12:02 AM   #162
PHXDEMON
PHXDEMON's Avatar
HELP!!!!!!!! PLEASE!!!!!!!! I am in the middle of installing this TB with the afe intake the issue I am having is the coupler for the intake is hitting the screws and wont go on all the way. I have tried with all my strength to push it on further with no luck. Also I am unable to wedge the hose clamp in between the coupler and the screws. Any Ideas? I was thinking about shaving out some of the inside of the coupler, but how would I go about doing it? here's a pic so you can see what I amj talking about.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
