Old 05-05-2009, 09:55 AM   #55
eric81
eric81's Avatar
Drives: Toyota Salesman
Originally Posted by 07WYarisRS View Post
Redline and Amsoil are about the top 2
oils as classified in 5 groups
group I oils are the cheap junk like castrol GTX, Q state etc
group II oils are better nown as syntheitc blends as they are a mix of group I and group III oils
Group III oils are what 99% of synthetic oils are made of... These oils are synthetic oils made from mineral/crude oil. Most use the hydro cracking method and use heavy amounts of pure synthtic base stocks as additives. Group III are far better then any group I or II oil. Castrol Syntec and Mobil 1 are examples of group III synthetics.
Group IV ~ V These are the best of the best and are not actually oil. these are lubricants but called oils to not confuse the mass public...These are not pumped out of the ground, instead and made by folks in white lab coats. Most contain extremely small amounts of mineral oil or no mineral oil at all. Group IV synthetics are POA based ( Polyalphaolefin )
group V are usually Ester based synthetics
Redline and Amsoil products are bother a group IV-V synthetic and contain no mineral oil. This eliminates any mineral by products that oxidize and form sludge and engine deposits.
I should point out BOTH buy their synthetic stock from Exxon/mobil1 so you know even though the formulas are different the base stocks use in Mobil1, Amsoil and Redline are all the same.
Royal purple Racing oils are group IV-V however the regular stuff is group III...
If you can't find or afford a group IV-V synthetic... be sure to use a quality group III like Mobil 1.
My #1 choise is Amsoil, Redline is also great but far fewer products available
don't forget... the engine is just 1/2 of it... be sure to change the transmission fluid as well. 75W-90 for the Manual trans and the universal ATF for the auto's.
Thanks for the heads up... I bought the prepaid dealership maintenance, which takes care of oil changes (except for the $8 difference between regular oil and synthetic... but the car comes stock with synthetic, so they force you to pay the difference... stupid if you ask me) and ALL things that they normally charge you for at the shop. Stuff like tire rotations, engine checks, and anything they touch while at the dealership. I thought it would be a good investment at the time, being in the Army and not having much time to myself, but I am selling it and my extended warranty back to them this week I have to fax in a paper requesting to sell back the stuff, and then they will apply it to my principal. Turns out the engine was easy to work on, and with all the stuff I changed, I am pretty sure my warranty is gone anyways. (CAI, header, exhaust, lowering springs, plugs, battery, and several other things will probably break their rules and void my warranty anyways. Oh well. Now I can work on my car without worrying about what rule I am breaking.
eric81 is offline   Reply With Quote
Old 05-05-2009, 10:02 AM   #56
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by NJBob View Post
I bought "S" wheels from "RocklandToyota" and put my steelies away for winter. The light came on when I changed.
Because the older S rims do not have the tire pressure sensors. you will need to transfer them from the steel wheels to your new ones. or get new sensors..
or just live with it.
Old 05-05-2009, 10:27 AM   #57
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
WRONG, i believe i gave him the sensor's which needed to be RE-programed to vehicle.....
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
