Old 05-06-2009, 11:22 AM   #181
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
my light kicked back on now after a while
ohh well, im just going to deal with it now
http://www.4055design.com
Old 05-06-2009, 04:27 PM   #182
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Originally Posted by MGargano View Post
Don't be surprised if the oscillation comes and goes for the first couple days. This happened to me and I thought everything was fine, then I got oscillation on the next cold start. Just be patient and give it a few days to work itself out.
Yeah it came back
Old 05-06-2009, 04:31 PM   #183
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Just out of curiousity, are you guys doing the coolant bypass? I was considering doing so unless this changes the way it idles. The 3k cold starts for 1 minute is all I want as far as weird reving goes. Dont want the bypass to screw with my fine idling.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-06-2009, 06:12 PM   #184
PHXDEMON
PHXDEMON's Avatar
I did do the coolant bypass. Drive to work today was great . I actually don't experience the high cold idle everyone else is. My cold idle is around 2k RPM just like stock. I did hower buy my TB from M911gt on here so he may have fine tuned the idle screw. I think if anything doing the coolant bypass will make it idle better
Old 05-06-2009, 06:19 PM   #185
eii
Rides canyon walls
eii's Avatar
Just to clarify things, the coolant by pass i just just hooking up together the two coolant hoses that connect to the TB, right? You dont do anything to the little metal thingies on the TB the hoses were connected to? Just leave them be?
Old 05-06-2009, 06:25 PM   #186
MGargano
Drives: 2009 Yaris Hatchback
I plugged the tubes on the TB, but I've heard others have left them as-is. And yes, you just have to use a barb union to join the two hoses together.
MGargano is offline   Reply With Quote
Old 05-06-2009, 07:07 PM   #187
PHXDEMON
PHXDEMON's Avatar
Correct others have plugged them I just left them as is. Just go down to a lowes/home depot/etc and get a coupler barb for 3/8 inch ID vinyl tubing and you are food to roll. Stock clamps work and everything just need the barb.
Old 05-07-2009, 12:55 AM   #188
kustom play
Drives: 07 liftback
my light went off again today
keeps going on and off
i hope it just stays off for good now
Old 05-07-2009, 07:31 PM   #189
eii
Rides canyon walls
eii's Avatar
Cool thanks guys. I'll probably stop by lowes once my paycheck arrives, hazzah!
Also, I'm using the simotoa carbon charger CAI. Buy a 2.5" silicone coupler at your local auto parts store and that should work perfectly.
Old 05-08-2009, 11:35 AM   #190
kustom play
Drives: 07 liftback
my light keeps going on then off on then off
im about to put my foot up its ECU
Old 05-08-2009, 11:41 AM   #191
hatchbackkid82
Drives: .
So judging by the 186 post, no one has figured this out yet. I had this on my car and could not figure out how to turn the CEL off. I just came to the conclusion that just b/c a part fits on my car doesn't mean it belongs on there. I think there are only a handful of members that have done this mod sucessfully(i.e. No oscillation, no CEL)
Old 05-08-2009, 07:07 PM   #192
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
hey guys would the 1zz-fe from toyota matrix works as well???
Old 05-08-2009, 07:10 PM   #193
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^ same one as the corolla
Old 05-08-2009, 07:21 PM   #194
kustom play
Drives: 07 liftback
CEL doesnt effect the performace
you honestly have to expect that type of stuff when you swap parts that were not made for your car
im just going to live with it, in 5 years when i have to get the car inspected, i'll spend the 5 mins and put it back to stock
Old 05-09-2009, 03:37 PM   #195
jkuchta
Drives: 2007 Yaris hatch (red)
Kustom...what is the CEL code?
jkuchta is offline   Reply With Quote
Old 05-09-2009, 06:46 PM   #196
PHXDEMON
PHXDEMON's Avatar
I am still getting oscillation like a motherfucker (1-4k RPM) but no CEL. Hey kustom I'll trade you my oscillation for your CEL. I pulled up next to a STI yesterday and looked like some faggot ricer revving my engine. I am debating just throwing my stock exhaust back on so it isn't as obvious that my engine is revving.
Old 05-10-2009, 11:21 AM   #197
marcus
toyota
marcus's Avatar
lolz.. this thing can get you in trouble..imagine lining up with a copper on a stop light...
Old 05-10-2009, 06:06 PM   #198
PHXDEMON
PHXDEMON's Avatar
I started killing my engine at stop lights I bled the coolant today and it didn't make a difference. It seriously seems like the oscillating is getting worse and it is pissing me off. I am going to make one final attempt to reseal/remount the TB and let it set for 24 hours while the battery is disconnected and if it is still giving me crap after a couple days I'm just pulling this fucker off. Also I tried the whole rev the engine up to 5k for 3 minutes thing but after 2 minutes my engine started backfiring so I stopped.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
