#37 |
Which TB you put on it??? I know someone told it but check if the TB port match because you'll have a restriction over there, remember it will suck air from a 1.75" or something like that in the stock port of the 1nz vs if you port to 2.25" like the 1zz or the TB you used. If you don't port will not gain too much.
#38 | |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I Drive a 129whp Yaris ;) |
#39 |
Ok yo estoy haciendo una ara~a en aluminio pa ese throttle despues te envio par de pics... y estaba pensando hacer spacers en plastico y aluminio...
#40 |
Me avisas cm va ese proyecto
#41 |
![]() ![]() Drives: 06 Toyota Vitz RS Join Date: Apr 2009
I paid about US$112 installed, great sound will post youtube asap, just trying to do the tb swap this weekend hoping to pickup a 1zz tb at any of the local used parts shops if not I'll get it from Garm, set up with the swap already.
| My DynaPack Dyno Results. | PETERPOOP | Performance Modifications | 63 | 03-10-2009 06:02 AM |
| TS/Xd Long Tube Header & Intake dyno results | richardholdener | Yaris TS Talk | 21 | 01-06-2009 05:28 AM |
| Long Tube Header Dyno results & Photo | richardholdener | Performance Modifications | 59 | 11-26-2008 05:27 PM |
| dyno results are in!!!! | turboyaris | Performance Modifications | 105 | 04-01-2007 06:03 PM |
| WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! | WRLEO | Sponsors Classifieds Area | 0 | 02-22-2007 10:14 AM |
