Old 06-10-2009, 11:34 AM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
TB dyno results
look this is what whp i have now with the tb upgrade. Look in the stick above for my previous dyno. about +3 whp but it sure dont feel like it
Old 06-10-2009, 11:38 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
3whp is impossible to feel
Old 06-10-2009, 11:40 AM   #3
fuji
fuji's Avatar
Drives: Polar White Yaris HB
It's a start! Thank for the work!
fuji is offline   Reply With Quote
Old 06-10-2009, 11:40 AM   #4
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
that graph shows a lot more than 3 whp increase..u sure ur reading it right
Old 06-10-2009, 11:41 AM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
3 hp can be related to temperature, humidity or several other variables.
But, you can't just look at peak HP. Peak HP is good for one thing and one thing only: bragging rights. Who cares? Look at the torque curve before and after. Did you sacrifice any torque to get a smidgen of extra peak HP? That's what's important.
Old 06-10-2009, 11:43 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
what mods do you have to make 111whp?
Old 06-10-2009, 12:03 PM   #7
Yoda
Yoda's Avatar
same variables as the list time. and actually its hotter now since its summer than when i did it in the spring. did not lose any tq but gained about 3 also. Peak Hp is what basically all the dynos post here have been using so i though it was relevant.
Old 06-10-2009, 12:08 PM   #8
Yoda
Yoda's Avatar
http://www.yarisworld.com/forums/sho...132#post333132
post# 61
Old 06-10-2009, 12:09 PM   #9
mrbond
mrbond's Avatar
I, too, would like to know. That's about...13 whp higher than stock, or thereabouts.
Edit: saw your post just after I made mine :P
- A Toyota Yaris
- A whut Yaris?
Old 06-10-2009, 12:14 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
13HP at the WHEELS over stock.. which is crank rated hp
edit.. n/m lol
Old 06-10-2009, 12:19 PM   #11
mrbond
mrbond's Avatar
a 13whp gain over stock is not bad for five bolt-ons.
- A Toyota Yaris
- A whut Yaris?
Old 06-10-2009, 12:23 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
sounds like a fat dyno to me... plus the guy didn't even bother grabbing a crank signal.. mph dyno graphs blow.
Old 06-10-2009, 12:23 PM   #13
Yoda
Yoda's Avatar
yea hmm wat next... Custom cat back i guess.Need to get rid of my steelies and get something lighter too. Still doing my research for F/I. Trying to understand the basics of tuning. So much info.
Old 06-10-2009, 12:25 PM   #14
way to go -- the TB swap makes power.
Old 06-10-2009, 12:25 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
buy the hks kit and modify it
Old 06-10-2009, 12:28 PM   #16
Yoda
Yoda's Avatar
he did do it i just forgot to put it in rpm. Just match it with the others it is a mirror basically. Every dyno is diff usually with this low whp you can expect a +/-2 variance. it could be fat or the others could just be stingy
Old 06-10-2009, 12:30 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
agreed. and this is why you should always return to the same dyno for every new pull :)
Old 06-10-2009, 12:32 PM   #18
Yoda
Yoda's Avatar
i did everything was done the same. and as a plus it is hotter now since its summer.
My DynaPack Dyno Results. PETERPOOP Performance Modifications 63 03-10-2009 06:02 AM
TS/Xd Long Tube Header & Intake dyno results richardholdener Yaris TS Talk 21 01-06-2009 05:28 AM
Long Tube Header Dyno results & Photo richardholdener Performance Modifications 59 11-26-2008 05:27 PM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
