#19 | |
14.52lb/hp with me in the car though
#20 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
well, maybe 'keep up' rather (13.2 or so it looks like), but still that's awesome
#21 |
this is the first time I have posted my thoughts and theories on a thread where someone hasn't bashed the heck out of me. Thank you.
Also, as for turning, I am in the understanding that the wider tires, 1.5" or greater lowering springs, rear sway bar, and taking the dead weight out of the back of the car is supposed to make this thing the turning CHAMPION! I personally have only lowered my car 2" and taken out the tire and jack, then put the rear seats down towards the front to keep the weight off of the back. Turns great, but I do notice that the front end jumps around a lot if it is not a perfectly level corner. The tires will spin, or drag the grab all of a sudden like, or just slip all the way through, losing speed and inertia. I am sure tires would help a lot (185-60R15's are a waste of rubber for a bigger tire, imoi) but I bet a lot has to do with weight. I also usually take corners in 2nd, near 30 to 40 mph. Any slower I stick it in 1st and wait to get out of the turn then floor it and spin them just to make noise. WAY off subject now. If anyone lives near Pueblo, CO, IM me about the car show this weekend. I want to know if anyone will be going, or even showing their car. |
#22 |
you need:
1.tires 2. driving lessons (talk to Loren :) )
#23 |
Audio Junky
haha... fair enough... tho i'm all into the relatively lightweight stereo setups... The subs in my avatar are only in there until I get access to the tools I need to do my install... total stereo weight will only be around 20-30lbs... plus another 50 for sound deadening.
#24 | |
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
For revolving mass like flywheel. pulley, rims etc, the basic rule is :
each 1 lb is like 7 lbs of dead weight. Example : If you save 2 lbs for your wheel and tire combo X 4 of them it = 8 lbs is like removing 56 lbs from the car. is Quote:
#25 | |
the farther the weight is from the spinning center, the more inertia you have to overcome...the smaller the diameter, the closer the weight is to the center b/c all tires and wheels are different, I don't think there is a great rule of thumb, but there is a method for determining the actual values by spinning the wheel/tire and determining the moment of inertia, but I do not actually know how-- something to do with tieing a weight with a string and watching the weight fall (spinning the wheel with it)... http://dev.physicslab.org/Document.a...ertiaWheel.xml here's another method, using a pendulum and torsion bar: http://www.velonews.com/article/79893 I'm also not sure having a lighter flywheel necessarily means your car will be faster, it just means the engine can rev with a quicker response, both up and down-- you still have to push the same car around. now having lighter but strong pushrods, cylinders, camshafts, etc., would be interesting for a higher redline; in which case that lighter flywheel would be pretty handy I bet |
#26 |
I didn't now there was an actual formula, but I bet it changes with FF, FR, MR, and RR types of cars, and changes again when you figure the original weight to weight ratio (dead vs rotational), and yet again when you figure the RPM's your car runs at. My car, for example, is about 2,100 lbs plus me, and you could probably guestimate about 200 lbs or so are rotating or moving, and it is a FF, and I find I get most power at or above the 3K mark, so if it gets down to 2K, I am usually down shifting, to keep it between 2K and 4K, sometimes higher if I am racing it to the next corner, or passing, or whatever. Then you have to figure how much the engine is working to get air in and out, and all of that fun stuff. In the end, it really comes down to "test and check", meaning put the stupid part on, and see if you notice a difference or not. My headers make my car loud, and I can feel the car needs more RPM's to get going, but it gets those RPM's a lot easier, so it was worth it to me. Same with the intake and muffler. I also put a stronger battery in, and put high quality iridium plugs in. Just my preferances. Along with Penzoil Full Synthetic, ($20 for 5 qts at Wal-mart) and a fram filter because the Mobil stuff they put in my car was BLACK, even from day 1, and I paid the extra $8 for the good stuff. In my opinion, I feel my car is now working slightly more efficient, and my MPG's show that. Even with racing it, I still average 38 mpg's.
That electric motor thing is a great idea, except that it has already been done by Honda, (I think that's the company, anyway's) and it is GREAT except that it costs so much money to do, it isn't worth it in the end. |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Weight Reductions | scape | General Yaris / Vitz Discussion | 34 | 06-08-2009 02:31 PM |
| Weight Savings | 03Z33 | Performance Modifications | 30 | 01-31-2009 04:14 PM |
