Old 06-21-2009, 12:45 AM   #1
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
power to weight
what's the power to weight ratio? I'm just wonderin what lb/hp would be for my car. I'm just curious
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 06-21-2009, 12:49 AM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
how much does your car weigh?
and typical stock yarii dyno now at what, 93whp?
Originally Posted by xnamerxx
you nailed it sir.
Old 06-21-2009, 12:49 AM   #3
Morgan
Morgan's Avatar
Drives: 07 MM LB
your car's curb weight divided by your car's horsepower
Each car is slightly different to get a rough calculation, you can use stock numbers
Old 06-21-2009, 12:19 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
how did you get 10.5?
I got 21.7:1
2300/106 = 21.7
I remember playing GT3 on PS2 and getting some of those cars to like 1:1.1 Thinking the Mazda 787B was one of the best.
Old 06-21-2009, 12:21 PM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I got 21.7:1
2300/106 = 21.7
You didn't account for your 200 pounds of stereo equipment and your own weight, unfortunately.
(and the car weighs closer to 2400 in stock trim)
Old 06-22-2009, 12:41 AM   #6
eric81
eric81's Avatar
Drives: Toyota Salesman
My car weighes 2,380 with me in it, and spare tire and all. I am about 200 with clothes, tire is almost 10, jack and spare parts about 40 or so, and then I took off heat shield, put in aftermarket battery, (slightly less weight, maybe 3 or 4 pounds) and I have NOT added any stereo equipment. Now, I drive a 5 gear manual, so it is a little lighter than an auto, but all in all the same. I figure my car is pushing close to 110 hp, all parts and improvements in place, so the car is about 2100:110, or we could just say about 19:1. Not bad all said and done, but then there is the difference between dead weight and rotational weight, which I explained before, but will gladly do again.
First off, dead weight is the frame, body, battery, engine block, seats, windows, and anything else not rotating with the engine to make the car go. Then you have rotational weight, which is cams, pistons, crank shaft, pulleys, tranny, rims, tires, axels, a/c, alternator, and fun stuff like that.
If you take 5 lbs of dead weight off the car, like the spare tire, for instance (it is more than 5, but just follow me here), then your car might possibly get about .1 seconds faster on the 1/4 mile time, and maybe .5 mph faster. Now, take the same weight off of your pulleys (NST kit, for example, for just $240 or close to that), and you will get about .5 seconds or better, and easily achieve 2 or 3 miles faster on the 1/4 mile end.
How is this so? Well, it takes more energy to rotate something than it does to simply push/ pull it. There is this new thing (at least, it's new to me) called "knifing", which simply means "smoothing the edges on the crank shaft so they form a smooth edge, so the crack shaft can flow through the oil faster and with less resistance and weight" It costs a lot to have it done because the crank shaft has to be rebalanced, but the results in top end horse power, and the time it takes to rev the engine from idle to max, are incredible. If I ever get enough money to play with, that is one of the main things I would like to do to my car.
So, weight to power is not everything, just to be clear.
eric81 is offline   Reply With Quote
Old 06-22-2009, 03:43 AM   #7
I think .1 second per hundred pounds is closer for a general rule, right?
Old 06-22-2009, 04:53 AM   #8
CDavis7M
Drives: 1990 Supra Turbo
+1. This applies to sprung mass, with unsprung or rotating mass giving a much greater benefit.
CDavis7M is offline   Reply With Quote
Old 06-22-2009, 10:38 AM   #9
MadMax
MadMax's Avatar
I have a 396 lb (dry weight) motorcycle with 150 HP, if I want to feel unadulterated acceleration, I take the bike out...even with a full tank of gas (less than five gallons), oil and my 215 lb fat ass on it, it'll pull like there is no tomorrow...
I don't worry about the power-to-weight ratio in the Yaris, that's not what I ever expected out of--or intended to do with--the car...
Old 06-22-2009, 11:20 AM   #10
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
http://yarisworld.com/forums/showthr...ight+reduction
the bottom of that first post is a power to weight calculation
Old 06-22-2009, 02:40 PM   #11
eric81
eric81's Avatar
yeah, it is closer to 100 lbs per .1, but probably not quite that much. That calculator is better, but it still does not account for everything, such as how high the car sits for drag ratio and wind resistance. Or how tall and wide the tires are. Taller tires will spin slightly faster, while wider tires have more resistance, but get better grip at the beginning and in turns. That is why you pay the insane amounts of money for cars that are calculated and engineered to perfection, like Porsche, and Lambourghini (sp?), and Ferrari, and Lotus, and stuff like that. Still, taking dead weight out of a car is a great way to make it turn better.
Old 06-22-2009, 02:49 PM   #12
scape
scape's Avatar
well for sure power to weight calculation of dead-weight is dead on, but I'm guessing you're referencing the rotational weight reduction; I totally agree there is no single method to determine that, and I'm def. no engineer :D
Old 06-22-2009, 03:01 PM   #13
eric81
eric81's Avatar
Yeah, any way you look at it, rotational weight is the place to do the reductions, unless cost is the main issue, then rock on with your bad self. I am not an engineer either, just like to research stuff like that. That's why lighter oils help improve power (even if it's just 1 to 3 hp), because the less resistance there is for the engine to work, the more it can put to the ground. That is why air intakes and headers and mufflers work so well. The engine works less to get air in and out, the more it can put towards the ground. Try sucking through a straw sometime, maybe 1/16" or so. Then try sucking through a straw that is 2/16" (or 1/8" for those who suck at math) and see how much easier it is. Same goes for your car. Slowly sucking is about the same, but suck something in really fast, and see how much difference there is. And it just occured to me how dirty this all sounds, but trust me, the idea is sound, and it has been proven by a LOT of companies.
Old 06-22-2009, 03:15 PM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
you nailed it sir.
Old 06-22-2009, 03:38 PM   #15
scape
scape's Avatar
lol, and I believe you that there are priorities in tuning a car for performance...
either way I was just pointing out something to the OP. but we can talk about engines too ;)
I think if you're looking to put the most power to the ground, your best bet is removing the entire transmission/driveline altogether and using generators and high KW AC motors-- then you will have the most efficient engine to ground power transfer possible-- and also an unbelievably expensive car. but perhaps this is all for a different thread
Old 06-22-2009, 03:45 PM   #16
Tamago
Tamago's Avatar
Drives: ZZW30
my car used to be 13.54lb/hp :(
you nailed it sir.
Old 06-22-2009, 03:47 PM   #17
gokartride
Drives: 2009 Yaris 3-Door Liftback
I have a friend who was into tuning Volkwagons and Porches and Triumphs back in the day....he says there is something "just right" about 100 hp in a 2,000 lb car. "Just right" is fine as the whole "need more hp" thing is totally lost on me. I've always said "if a car isn't fun while driving the speed limit, it's just not good enough"...but then I come from Sprites, Midgets, and Spitfires. The Yaris' delightfully twitchy and snappy turning radius are the fun part of this car for me, and I can use that every day jsut driving around town. The car plenty of power, imo.
gokartride is offline   Reply With Quote
Old 06-22-2009, 03:56 PM   #18
scape
scape's Avatar
what car was this? that's a good ratio! probably could spank a stock evo with that, haha
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 10:08 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
When will the Yaris hit the showrooms at dealers? Petrolhead New YARIS Purchase Forum 181 11-28-2011 08:03 AM
Weight Reductions scape General Yaris / Vitz Discussion 34 06-08-2009 03:31 PM
Weight Savings 03Z33 Performance Modifications 30 01-31-2009 05:14 PM
