Old 06-26-2009, 11:49 AM   #19
yeah they look aimed far too low! I had the opposite problem with mine, my cutoff was too high.
If you take out the headlights again, look at the back, there should be 2 screws that you can use the adjust the aim. You'd need to screw each one in equally, 1 full turn should be enough. It's a bit of a pain but not too bad...
Old 06-26-2009, 06:45 PM   #20
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Park your car on a level surface against a wall, about 3m away. Then adjust the passenger side UP until it's level with your driver side beam. When both side's cut-off line up then it is level. You might be able to adjust them without taking the light out again, I'm not sure how these lights look on the rear.
Old 06-28-2009, 08:34 AM   #21
elijahsami
Drives: yaris hatch & sedan
I adjusted my lights and they give amazing coverage...and it took only one minute or less thanks so much for the information guys...... And the best thing was i didnt have to take my lights off as suggested by some members in other threads.......thank you all for helping cheers
elijahsami is offline   Reply With Quote
Old 06-28-2009, 10:59 AM   #22
dirtking180
Drives: Toyota Yarsi Sedan 2007
Can I get these projectors for a Sedan Yaris....I've searched everywhere but the only one I found are for the 3drs....????
dirtking180 is offline   Reply With Quote
Old 06-28-2009, 11:40 AM   #23
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
after photos pls..
Old 06-28-2009, 03:01 PM   #24
I would probably do HID's even if it says not to on the low beams. You can then adjust them not to blind oncoming traffic. The only risk is that the housing cannot handle the increased heat, but I personally would take that chance.
Old 06-28-2009, 04:30 PM   #25
marcus
toyota
marcus's Avatar
aint the hid running cooler that regular bulb since its 35 watts rather than 55 watts.
Old 06-29-2009, 06:31 AM   #26
elijahsami
after photos pls..
Before....low beam
After
High beam
Old 06-29-2009, 06:37 AM   #27
elijahsami
I was gonna do that and i also was gonna buy the heavy duty harness from you thats untill some kind people suggested me to adjust my aiming at the moment im pleased with the light output but i will get hids after i do more mods. Thanks for the tip mate
Old 06-29-2009, 06:42 AM   #28
elijahsami
At the moment i havent found a seller but i am looking for a pair myself as i have both a sedan and a hatchback if i do find a seller i will tell all of ya
Old 06-29-2009, 08:59 PM   #29
jonismyname
Drives: 08 liftback 5spd
Originally Posted by KoDoK NyeLeM View Post
Nice Speedo
how'd you know what he was wearing while taking the picture? amazing.
jonismyname is offline   Reply With Quote
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
Halo Projectors gwasabi Cosmetic Modifications (Exterior/Interior) 4 02-28-2009 02:25 PM
Depo halo projector help Chaubii Cosmetic Modifications (Exterior/Interior) 5 01-26-2009 11:42 PM
Problem with Projector Halo :( jmew0ng Cosmetic Modifications (Exterior/Interior) 6 01-15-2009 09:08 AM
Halo Projectors thatboyjer Cosmetic Modifications (Exterior/Interior) 0 10-22-2008 12:16 AM
