Old 06-30-2009, 01:33 PM   #55
texkid
The one with cheese on it
Drives: '10 Corolla S
Originally Posted by Sandwash View Post
With such an obvious improvement to effectiveness (and efficiency) of AC system you would think Toyota would develop a standardized 'fix,' provide a service bulletin to their dealerships, thus allowing them to bill their customary 'arm and leg' charges for those customers willing and able to go that route.
I agree.
I still want to assume that they probably NOT do this in order to save on building costs. Because if you look at the whole car itself, there isn't another part that is insulated. So I imagine that they probably thought "why purchase insulating foam (or other material) for one stretch of pipe" and just left it at that?
texkid is offline   Reply With Quote
Old 07-01-2009, 02:14 AM   #56
Pitt Yaris
Drives: Flint Mica Sedan
I'd like to do this. My a/c at a level 4 is no cooler than a friend's (old buick) a/c at a level 2.
Old 07-01-2009, 08:44 AM   #57
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Well now, those old Buick ACs could be used to freeze a hockey rink. Probably draw off half the power the Yaris engine's capable of producing, too.
Old 07-03-2009, 06:19 PM   #58
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
Originally Posted by hatchbackkid82 View Post
I'm gonna have to try this
That's what I said today!
So I took photos along the way.
File Type: jpg 3.run_to_expansion_chamber_from_cabin.JPG (108.5 KB, 425 views)
andaconda is offline   Reply With Quote
Old 07-03-2009, 06:21 PM   #59
andaconda
andaconda's Avatar
ran out of aluminum tape - will finish the job after the holiday...
Old 07-03-2009, 06:23 PM   #60
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Did the a/c cooling improve?
Old 07-03-2009, 06:37 PM   #61
RedRide
RedRide's Avatar
I've ony had my Yaris for a couple of weeks now, however it's becoming rapidly evident that Toyota left no stone unturned in its effort to cut cost to a minimum.
I'm not complaining as I wanted an inexpensive, no frills car.
As to why no TSB on this issue.... If they had one, that would be like admitting that there is a problem.
Old 07-03-2009, 06:49 PM   #62
andaconda
andaconda's Avatar
Not sure yet, as I only checked for clearance with the insulation.
I did check my wife's Baja, and the sister-in-laws Aveo today - neither of them has any insulation whatsoever.
I can't see how this mod could possibly hurt anything at all! (other than a few cuts and bruises.)
Old 07-03-2009, 07:26 PM   #63
auxmike
auxmike's Avatar
Yeah, looks like you hit something sharp! Mabye a glove would help prevent this for the others???
Old 07-03-2009, 07:33 PM   #64
andaconda
andaconda's Avatar
Are you kidding me? I can't work with gloves. I get cut up if I even look at the underside of a car.
Besides that --- what's a little mod without a little blood?
Old 07-03-2009, 08:55 PM   #65
texkid
That is definitely true. Besides, gloves were useless to me when I was smelling some burned arm hair.
If you don't mine, stick a meat thermometer in the air vent and let us know what temp you're getting when driving.
I noticed that mid-morning and after around 17:00 my temps go as low as 37-ish degrees.
DIY: A/C Insulation
Old 07-03-2009, 09:38 PM   #66
firebob
Drives: 09 yaris
If there’s not blood then you didn’t do anything.
I truly don’t think there’s a big issue with the AC as it is stock. I have looked at other cars still sitting on the lot and they use metal lines that are not insolated for part of the run also. I have driven plenty of other cars, SUVs, and trucks but I think the Yaris is as good or better with it’s cooling capabilities. Could the problem start after mods have been done that changes the temp under the hood?
If you have your AC on and you’re not running the fan wide open then why run the compressor and make the motor work harder for no reason?
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 07-04-2009, 12:22 PM   #67
PatrickJohnson
Drives: 2008 Yaris LB
The cooling was good before, but after doing this mod and driving for about a week, it is a night and day difference.
PatrickJohnson is offline   Reply With Quote
Old 07-04-2009, 02:52 PM   #68
Yaris Hilton
Smile
Your tetanus shots up to date, Andaconda?
Old 07-04-2009, 02:58 PM   #69
firebob
Drives: 09 yaris
I’m sure there is a good difference in doing this. I’m just saying that with the car stock it is as good other stock cars that are on the market.
Old 07-04-2009, 03:01 PM   #70
Sora65
Drives: Beautiful :)
Yeah im about to do this today. hopefully works out well.
Another question.
for the yaris sedan.. the one i have...
can you insulate passed the tube. like where the pipe line hits the compressor?
It kinda looks like a pain to do. but i like cold :)
Sora65 is offline   Reply With Quote
Old 07-04-2009, 03:12 PM   #71
andaconda
andaconda's Avatar
When I take it out of the garage on Monday, I'll take its temp.
Old 07-04-2009, 03:16 PM   #72
andaconda
andaconda's Avatar
Instead of turning the temp down or up, I'm in the habit of pressing the air "on/off" button so that the compressor will only come on when I want to cool off.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 05:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 02:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 10:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 03:56 AM
