Old 07-18-2009, 08:55 PM   #1
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Quick question re: revolutions per mile
If my OEM tire (goodyear eagle ls) was rated at 880 revs per mile, and my new tire (hankook rs-2's) are rated at 915 revs per mile, then does that mean that i've been calculating my MPG's incorrectly?
So hypothetically lets say a round number like 400 miles on a fillup, of 10 gallons of fuel. This would net me 40mpg's.
So the ratio of the new tire (915/880= approx 1.03977% change) would change it to 400 milesx1.03977= 415.9 miles? So then that would change my MPG from 40 to 41.59?
What i'm trying to aSK is does the speedo recalibraTE for my new tires, or do i need to multiply it (1.03977) every tank in this case?
thank you!
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 07-18-2009, 08:58 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
speedo does not recalibrate.
you do have to factor in your new wheel circumference.
Old 07-18-2009, 09:03 PM   #3
anonymous user
Drives: 07yaris
Thanks Tamago, then that means i have been "underestimating" my mpgs for all my cars (not that it matters much when i get 13 MPG in the wrx coming out of a straight at 130 entering a chicane..haha)
Old 07-18-2009, 09:48 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
actually, overestimating.. if you went with a smaller overall diameter, your actual GROUND mileage is less than your odo tells you. odo says you've traveled 400 miles when you've actually only gone 384.7 miles.
Old 07-18-2009, 10:51 PM   #5
EasyDriver
Drives: 2008 Yaris Meteorite LB
tire size....
thank you!
http://www.miata.net/garage/tirecalc.html try this site for the info you want....
EasyDriver is offline   Reply With Quote
Old 07-19-2009, 02:24 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
If your tires are turning more times per mile, your speedometer is now reading faster than you're actually going, and your odometer is showing more distance than you've actually gone.
Old 07-19-2009, 06:51 PM   #7
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Drives: 2007 Silver Liftback
I agree with Yaris Hilton, that you have been showing more distance than you've actually gone. What I do suggest is this......next time you go a long distance on a highway that has mileage markers, keep track of your odometer and what the highway markers shows. Very likely they will show different distances. The highway will show less miles than your odometer.
GL, Roadrunner
roadrunner is offline   Reply With Quote
Old 07-19-2009, 10:36 PM   #8
The little red pill
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles"
Another option, If you have a portable GPS, most will show your realtime MPH and you can use that instead of your speedometer. I have a Garmin Nuvi 255w and it shows my MPH on the main screen.
2009 Absolutely Red LB. "Bubbles"
The little red pill is offline   Reply With Quote
Old 07-20-2009, 02:00 PM   #9
Zaphod
Drives: Big Yellow
Can't you just change your speedo gear?
Zaphod is offline   Reply With Quote
Old 07-20-2009, 02:25 PM   #10
MadMax
MadMax's Avatar
It's electronic, not mechanical. I am not sure if the ECU is reprogrammable and it has always made me wonder as I have larger wheels on my Yaris and my speedo is spot on according to my GPS.
That means either the dealer reprogrammed the ECU/speedo when they put the wheels on, or the stock settings on the speedo are off.
Old 07-20-2009, 02:41 PM   #11
Tamago
Tamago's Avatar
Drives: ZZW30
there IS an actual speedo gear in the transmission though... just not sure how you'd shim it since it's fed from the end of the speedo sensor and top loaded on the differential.
Old 07-20-2009, 02:45 PM   #12
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
You are actually decreasing the value of your car with every mile your odometer shows. If you car is going a mile but shows 1.2 miles (for example) you are racking up more miles that are going to make the value of your car less in a few years.
Also your car insurance might be over charging you for insurance if they are rating your coverage by the miles your odometer is showing for annual mileage.
Of course if you keep the car until the wheels fall off, it doesn't matter what size the wheel is.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 07-20-2009, 02:48 PM   #13
Tamago
Tamago's Avatar
Drives: ZZW30
LOL you are actually decreasing the value of the car by driving it no matter what the odo reads..
Old 07-20-2009, 05:26 PM   #14
Zaphod
Drives: Big Yellow
It may be even easier then, just give the ECU the new diameter and you're good to go.
There has to be a way to make it work though, as popular as it is to change wheel and tire sizes these days. I'm thinking that a dealer might have legal issues with changing the diameter without recalibrating the speedo.
Old 07-20-2009, 05:27 PM   #15
nemelek
DWEED
nemelek's Avatar
Originally Posted by roadrunner View Post
I agree with Yaris Hilton, that you have been showing more distance than you've actually gone. What I do suggest is this......next time you go a long distance on a highway that has mileage markers, keep track of your odometer and what the highway markers shows. Very likely they will show difference distances. The highway will show less miles than your odometer.
GL, Roadrunner
I do this check myself. I drive 10 highway miles ane compair that to the odometer. If the odometer showes 11 miles for every 10 miles driven than it is now 9% fast. If your speedometer showes 110 mph you are actually doing 100 mph.
Old 07-20-2009, 10:44 PM   #16
daf62757
daf62757's Avatar
True, but the value decreases at a greater rate the more mileage the car has.
Big Dave
Indianapolis, IN
Old 07-20-2009, 10:54 PM   #17
Tamago
Tamago's Avatar
Drives: ZZW30
i wasn't arguing that point.
but it's a car.
and econocar
it's not an exotic.
use it for what it was meant to be. basic transportation.
Originally Posted by xnamerxx
you nailed it sir.
Old 07-20-2009, 11:06 PM   #18
EasyDriver
Try this for better understanding: http://www.miata.net/garage/tirecalc.html
reverse gear..quick question.. Yaris2910 DIY / Maintenance / Service 10 01-11-2011 06:14 AM
quick air filter question wingdood DIY / Maintenance / Service 3 05-11-2009 09:17 PM
Quick Newb Question? Grandieri Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-02-2009 12:40 PM
Quick question.. harveyjai Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-21-2009 06:38 PM
Stupid question...TRD Quick Shift Stargate YARlantIS DIY / Maintenance / Service 17 12-01-2008 12:46 AM
