#1 |
![]() ![]() Drives: 2010 Matrix Join Date: Feb 2009
Quick Newb Question?
So I used the search bar and was only able to come up with 1 thread that might answe my question. I found some cheap 15x6.5 and 15x7 both have +38.Will my stock tires at 185 60 15 fit these no problems or should I stick to one wheel size only. The yaris is lowered on teins and I"ve read up on rubbing issues. I'm not worried about that just wondering if I can strech the original tire enough to fit either size. Thanks Cory.
Drives: 2014 White VITZ Join Date: May 2007
You'll be fine with either wheel. ET38 will be okay with 185's which will fit wheels up to 7" wide.
This information, plus answers to many wheel and tyre questions can be found here: http://www.yarisworld.com/forums/showthread.php?t=5021 |
#3 |
Thanks sorry i knew it was a stupid question. I found it now just wanted some advice.Thanks again, Cory
| Quick question.. | harveyjai | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-21-2009 05:38 PM |
| Stupid question...TRD Quick Shift | Stargate YARlantIS | DIY / Maintenance / Service | 17 | 11-30-2008 11:46 PM |
| a quick question for USDM Yaris | chrisada_to2a | General Yaris / Vitz Discussion | 21 | 05-18-2007 08:57 PM |
| quick fuse question... | Blenjar | General Yaris / Vitz Discussion | 1 | 05-01-2007 07:34 AM |
| quick window tinting question...?? | static808 | Cosmetic Modifications (Exterior/Interior) | 8 | 10-16-2006 08:49 AM |
