Old 10-21-2009, 04:52 PM   #181
Update: I received the OZ cluster from Lewis today!
I immediately had to open the box and hook it up on Crashy. With the swapped connectors (since it is for a RHD Yaris) I just hooked up connector D1, which has power, CAN bus, fuel gauge, tach, speed, etc (the other just has the feeds for a bunch of the indicator lights).
It powered up fine and the fuel gauge showed proper level. So, I started the car and the tach worked correctly, but the speedometer stayed at zero. This cluster is off an ABS car, so that makes sense, as Crashy is non-ABS.
The issue though is that the cluster is indeed angled to... the passenger (at least on this side of the world). The VFD (vacuum fluorescent display) is reversed and is mounted in that chunk at the bottom and is pointed to the left. A concave mirror magnifies and inverts the VFD and angles the display to the USDM passenger.
Being an Engineer, I just had to take it apart to see how it was setup and to snap some pics. Here they are:
Powered up:
Close up of the VFD:
Close up of the clock/mileage VFD:
Concave mirror:
Old 10-21-2009, 04:57 PM   #182
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
So could you transplant the guts of the aussie cluster , into the USDM
unit , or is it not that easy
Old 10-21-2009, 05:02 PM   #183
The USDM one is just a flat plane. The Aussie one has the lens in the same place, but the guts and case are completely different to make the VFD work correctly. I was initially thinking that you could modify the bottom chunk and the back to point towards the left, but the upper portion has a molded tunnel that is angled from left to right. It would take some creative plastic work to make the display point left.
Old 10-21-2009, 06:24 PM   #184
*MAD DOG*
*MAD DOG*'s Avatar
Scott and Lewis,
Glad it works. Looks like some more work is required to make it useable for you though.
Scott,
I know you just got the unit, but is there any chance of a fix so the Km/L would work for us Aussies?
Old 10-21-2009, 06:31 PM   #185
*MAD DOG*
*MAD DOG*'s Avatar
I think this picture sums up this thread.
Old 10-21-2009, 11:37 PM   #186
bummer it doesnt work
so how does it look from the driver side? not well or is it kinda tolerable?
well back to looking for a USDM S Cluster
Without modification the speedometer/tach portion are really not viewable at all from the driver's side.
Old 10-22-2009, 12:48 AM   #187
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
sedan cluster should be the same size as the liftback cluster, but the plugs to connect are different from the liftback......
Also.....is your car ABS enabled kustom? If not, you will run into problems like Lewis and I.... :P
Old 10-22-2009, 01:20 AM   #188
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
I have someone on here who is test fitting a 09 w/ ABS cluster on his 07 non-ABS car....I'll let you know whether it works or not..
But: 08 w/ ABS accepted my RS cluster.
Scott's 08 w/o ABS didnt accept it His 09 with ABS did...
So i highly doubt yours would accept a cluster w/ a tach...speed data won't be sent the same way like it is through the speedometer only cluster~ jus saving you the trouble and money...
But go for it, we already have 2 other guinea pigs on here hahaha
Old 10-22-2009, 07:44 AM   #189
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
Unhappy One dead Guinea Pig
R.I.P. Oz Cluster
Lewis is offline   Reply With Quote
Old 10-22-2009, 08:07 AM   #190
so it looks like its a bust for LHD cars then :(
so looks like the only way to get a tachometer and speedo is the get the USDM tach/speedo combo then
Scott, Anyway to rig up a sedan cluster? How far off is the fit?
I always see those for sale and there super cheap!
The sedan cluster may (?) be the same size, but it mounts differently. It's mounting screws are out on the ends, rather than out in front. The right connector is the same (pinout and all). The left is a wider connector, but the pin functions are identical.
Old 10-22-2009, 11:03 AM   #191
so maybe it would fit if we could find a way to mount it?
but would it have the issues with the read outs? like say an 07 sedan with an 07 liftback?
I was just looking at sedan cluster pictures on ebay and the sedan one is a very different shape than the LB one.
Old 10-22-2009, 11:44 AM   #192
ok get back to making the tach fit the clock area
I'm making good progress on it.
Old 10-22-2009, 11:54 AM   #193
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
so demanding....lol
I wonder if the OZ cluster will have odo adjusting problems like my RS cluster....?
Old 10-22-2009, 12:00 PM   #194
so demanding....lol
I hooked it up to my test bench last night and had the same result with making the speedo change but the odo didn't increment. I just need to get to the bottom of the extra bytes in the speed message.
Old 10-22-2009, 12:07 PM   #195
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Did your 09 send any additional messages from my RS cluster that could help you out with that? I know you said you were going to try that out in my thread...dont know~
Old 10-22-2009, 12:17 PM   #196
My 09 sent the same data to both its own cluster and to your RS cluster. It's entirely possible that the odo increment data is sent in an entirely different message. I have 11 more messages from the 09 data capture to decipher.
Old 10-23-2009, 06:38 AM   #197
Lewis
Lewis's Avatar
Scott - what about starting a new thread keeping us informed on the progress and release of the Yargauge? It seems like the best answer for so many of us who want a tach but within the confines of the existing OEM cluster setup (i.e. not a separate tachometer on the dash and don't want to have to mess with the odometer flashing.
This thread on the OZ cluster is about as dead as a doornail.
Old 10-23-2009, 07:25 AM   #198
*MAD DOG*
*MAD DOG*'s Avatar
Maybe for you but not for me. I'm hoping Scott can figure out a way to make the Km/L and gear display work.
DIY - Change your Gauge Cluster Color vodkalush DIY / Maintenance / Service 89 04-29-2019 09:41 AM
FS: Gauge Cluster from '09 LB- $150 MGargano Items for Sale by private party 14 10-05-2009 12:59 PM
Shifter knob/gauge cluster color DevilGirl Cosmetic Modifications (Exterior/Interior) 3 08-11-2009 10:18 PM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
CLUSTER LIGHTS WENT OUT Go4th DIY / Maintenance / Service 23 01-25-2007 11:37 AM
