Old 01-19-2010, 10:11 AM   #1
DenverDave
Drives: 2010 Hatchback
Removing A-pillar cover
I managed to get the cover unsnapped, but can't pull it clear of the pillar because there is a plastic piece with a knob on the end of it thru the slot on the cover. I can probably force the knob thru the slot with some needle-nose pliers, but I was wondering what purpose it served. Should I just cut it off?
DenverDave is offline   Reply With Quote
Old 01-19-2010, 12:15 PM   #2
Kongo-Otto
Drives: '09 Yaris & '10 Auris
You have to rotate the (yellow?) knob by 90° to push it through the hole. Its some kind of a retainer system. If the curtain shield airbag pops out of the roof this knob holds the cover in place (with a little clearance of course). Don't cut it off.
Old 01-19-2010, 03:55 PM   #3
DenverDave
I stopped by Toyota and talked to a guy in the Parts Dept. He couldn't find a diagram that depicted the piece, so he came out to my car and I showed it to him. His first comment was that it had to do with the air bag system, and that was probably why Toyota didn't offer an auto-dimming mirror as an option in 2010. He recommended against running a wire down the A-pillar because it could interfere with the air bag deployment. This is probably not enough to deter those of you who are experts, but it was enough to deter me. All I wanted was a temp and compass display, so I was going to install a CIPA 36400 mirror. Too much trouble, and it's not that cheap anyway. I took a photo of the piece but couldn't figure out how to attach it.
Old 01-19-2010, 08:24 PM   #4
b_hickman11
Drives: 08 Sedan
I installed the auto-dim mirror and homelink in my Yaris from my 2005 Tacoma. I ran the wires down the A column in my 08 Yaris which doesn't have the side airbags. You could try to run the wires down the B column or C column.
Old 01-20-2010, 07:18 PM   #5
pariahdecss
Yarisomniac
pariahdecss's Avatar
Drives: 2009 5spd LB
Yes it is a retaining clip - you have to rotate it to get the cover off - but don't cut it, it is there for a reason . . . to prevent the A pillar cover from impaling you if the side curtain air bags deploy
pariahdecss is offline   Reply With Quote
Old 12-08-2013, 02:35 AM   #6
Lars
Yaris beginner
Drives: Yaris XP9F
Could anyone post some pics for this? Please?
I want to replace my tweeters... :/
Many thanks!
Lars is offline   Reply With Quote
Old 12-08-2013, 03:11 AM   #7
Lars
Yaris beginner
Drives: Yaris XP9F
I found a very nice how-to to get the a-pillar off here:
http://highfields-arc.co.uk/vehicles.../yaris2006.htm
If someone could post some pics for this it would be great... otherwise maybe I'll be the one doing it :p
Thanks!
Old 12-08-2013, 04:24 AM   #8
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I've pulled a wire for my handsfree mic and a wire for the dimming mirror (from a Corolla, I still did not manage to make it fit...), I simply tied them to the wire which is already running down and checked whether it would interfere with the airbag - I doubt it will.
dj92 is offline   Reply With Quote
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
FS: Black Aluminum Engine Cover (blitz s/c) frownonfun Items for Sale by private party 6 02-02-2010 03:21 PM
Question about painting the Engine Cover Blue_dragon_192 Cosmetic Modifications (Exterior/Interior) 11 08-05-2009 12:45 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
