#19 |
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
Tech data from the new 6 speed:
1.33 Dual VVT-i 1NR-FE 6 speed gear ratios 1st 3.538 2nd 1.913 3rd 1.310 4th 0.971 5th 0.818 6th 0.700 Reverse 3.333 Final 4.055 |
#20 | |
The C64 is used in the Lotus and I think the Corolla XRS. But all other gears are the same. I remember driving a '03 Yaris RS (Puerto rico spec.) that has the C152 in it. Same gears as the C52 from the '00~ Celica GT. With a 1.904 2nd gear and the 4.058 final you could do a burnout starting in 2nd. The C160 on the other hand has an even low 2nd gear and lower final. So I can only imagine how a hard launch would do from 2nd. Edit: Oops, went on a little rant there. Yes the C60/160 does have a higher 6th to the Yaris 5th, but the final is so much lower on the C60/160 that the end result is still more revs at the same speed. |
#21 |
![]() Drives: Yaris SR 1.33 - 3 Door Join Date: Jun 2009
My Yaris 1.33 SR gear knob...
#22 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
When launching with high throttle the 1st gear complete in almost 4sec and 2nd gear in almost 2sec. Infact during drag races I usually launch with 2nd gear since it's pretty low aswell. The main reason I installed the C160 since the trans is capable of more bhp compared to the C54 (stock one) and because it has the Limted Slip Differential. Why would you need a 6spd trans? |
#23 | |
would that work? c54 final drive w/ c60 gears in a c54 bell housing?
#24 | |
#25 |
#26 |
| Bad Speed Sensor? | dmehak | DIY / Maintenance / Service | 33 | 01-05-2011 09:17 PM |
| Max Speed in Each Gear for 5 speed man. Yaris with no tach?? | 09TRD | General Yaris / Vitz Discussion | 53 | 09-24-2010 04:18 AM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
| Have I mentioned how much I hate Speed sensors? | staticorex | General Yaris / Vitz Discussion | 13 | 05-28-2009 04:04 PM |
| Six speed | Snyprwlf47 | Performance Modifications | 16 | 11-24-2008 09:04 PM |
