Old 02-02-2010, 02:40 PM   #19
np
Old 02-02-2010, 03:39 PM   #20
YarisSedan
Drives: 08 Yaris Sedan
Just a tip put the lugnut on backwards when you are pulling out the new stud and make sure its 100 percent centered till the tapered part is flush against the back of the hub. You might have a use a washer between the lugnut depending on the threads. Also put a dab of antisieze on the tread when pulling it flush. And be careful when removing the lugnut off to put the wheel back on after you pulled the new studs in place they will be extremly burning hot to the touch.
Old 02-02-2010, 03:49 PM   #21
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Gotcha...knew most of that for the most part but does it take that much effort to pull them through that the nut/wahers/stud get that hot? Interesting. Thanks!
DerFlosser is offline   Reply With Quote
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
New Yaris + warranty Question hpvampiress New YARIS Purchase Forum 9 06-29-2009 06:39 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
