Old 04-02-2010, 06:21 PM   #1
bronzebullet232
bronzebullet232's Avatar
Drives: 2010 Black 3dr Lift Back
Question Traction Control Removal
I have a 2010 3dr and I want to take off the tractional control. It comes on when I don't need it. Would anybody be able to tell me how to disable it? A fuse? A Wire?
bronzebullet232 is offline   Reply With Quote
Old 04-02-2010, 06:33 PM   #2
severous01
whatever you do to disable it you'll lose your ABS as well
cheapest and easiest way is to pull the e-brake one click...but you're brake light comes on. its enough to disable abs but not enough to touch the shoes to the drums
Old 04-02-2010, 06:59 PM   #3
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
that disables the ABS? wtf, really?
and rather than dragging around with one click, why not just ACTUALLY BYPASS the switch?
Originally Posted by xnamerxx
you nailed it sir.
Old 04-02-2010, 07:16 PM   #4
bronzebullet232
i really want to completely disable it... so useless....
Old 04-02-2010, 07:42 PM   #5
Tamago
Tamago's Avatar
Drives: ZZW30
worst case, unplug your wheel sensors.
or sell the bucket and buy an older yaris sans-TC.. or a REAL car lol
you nailed it sir.
Old 04-02-2010, 08:08 PM   #6
ddongbap
One click doesn't drag the brakes. Especially when you don't do regular brake adjustments.
Old 04-03-2010, 01:23 AM   #7
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
On my '10 5-Door, pulling the e-brake one click causes the E-brake warning beeper to go off constantly.
Stove is offline   Reply With Quote
Old 04-03-2010, 05:35 AM   #8
ddongbap
Same with most of us probably. I pulled the harness that goes to that switch.
Not sure if it helps, but I pull the ebrake a few clicks to get some better brake balance when I'm at the track. Again, not sure if it helps, but my BUttdyno says it does.
Old 04-03-2010, 07:07 AM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
you nailed it sir.
Old 04-03-2010, 08:04 AM   #10
ddongbap
U mocking the buttdynojet elevenbillionty?
Old 04-03-2010, 10:51 AM   #11
zachryboles
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback
there was a post somewhere where they found the way to make the yaris turn off traction control with a weird combo like clutch in twice pull up ebrake etc. i dont remember where i saw that in the forum but with some research you could find it. Not sure if that was a TS thing though.
zachryboles is offline   Reply With Quote
Old 04-03-2010, 08:14 PM   #12
Stove
Stove's Avatar
On the US 2010 HB Models there is an option of having a switch to temporarily disable/turn off the traction control. After reading the DIY Cruise Control Threads, I'm starting to wonder if it isn't just a matter of finding the right points to tap into the wiring harness with an aftermarket push button switch.
The Factory switch is located in the center console were the Aux Jack is. In place of the Aux Jack actually. I'll pull some covers and see if there are any unused plugs in that location.
From 2010 Hatchback Owners Manual:
Old 04-03-2010, 08:55 PM   #13
127.0.0.1
no there is no switch on US models, despite what the US manual indicates
there is no wiring harness when there is no switch
Old 04-03-2010, 08:59 PM   #14
127.0.0.1
1) whatever you do to disable it you'll lose your ABS as well
2) cheapest and easiest way is to pull the e-brake one click...but you're brake light comes on. 3) its enough to disable abs but not enough to touch the shoes to the drums
1) incorrect. you can disable it and keep ABS
2) incorrect. use the 'procedure' to disable it. e-brake is for those
who can't use the search feature or google properly
3) incorrect. on properly adjusted brakes, this will cause brake rubbing and overheating of the rear drum assembly
Old 04-04-2010, 08:41 AM   #15
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Disabling TRC&VSC works very well on my Yaris with the "procedure". ABS is still working. I had much fun in the snow during the last months.
Old 04-04-2010, 10:45 AM   #16
Billiam
Drives: '10 White Yaris 4D LB
Someone correct me if I'm wrong...but I think for the '10 model, manual tranny versions have the on/off T/C switch and autos do not. Perhaps that's where some of the confusion is coming from.
Old 04-04-2010, 12:06 PM   #17
hondakiller99
Drives: 05 Scion xA
if im not mistaken , isntthe TCS run throught the steering wheel? like the actuall TCS on my car, i know its a scion but its a idea, is always off cuz i did a steering wheel swap with a quick realease hub and i no longer have the option for no traction control, which IMO sucks, cuz when it rains out here i have no chance and traction when i hit a puddle that is un-avoidable.... IMO no traction is mmeehh lol
hondakiller99 is offline   Reply With Quote
Old 04-04-2010, 02:39 PM   #18
Kongo-Otto
If have manual transmission but no switch. I can switch VSC&TRC off by doing a special procedure with ignition, e-brake and brake pedal. Its mentioned in this forum a couple of times.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
any how to's to disengage the traction control? OTA'sTOY DIY / Maintenance / Service 8 04-06-2010 05:26 PM
Invasive creature or standard feature? Small cars and VSC, ABS, and traction control Thirty-Nine General Yaris / Vitz Discussion 19 08-10-2009 12:29 PM
Traction Control ??? pennystocks General Yaris / Vitz Discussion 6 09-12-2006 08:14 AM
