Old 09-11-2006, 11:30 AM   #1
pennystocks
pennystocks's Avatar
Drives: 07 Civic Si Coupe(Black Pearl)
Traction Control ???
I know its not an option but w/ drive by wire it should be as easy to plug in the TCS computer. Anybody know anything about this? Like normal TCS is a diff comp than the PCM right?
pennystocks is offline   Reply With Quote
Old 09-11-2006, 12:02 PM   #2
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
From the old european Yaris TS, in order to disable the standart Traction Control you had to take out a fuse in the fuse box.
Old 09-11-2006, 07:17 PM   #3
pennystocks
So it must be a diff comp then. I wouldnt doubt theres a plug just waiting for it to be pugged in.
Old 09-11-2006, 11:12 PM   #4
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
I'm wondering if its interchangable with the Scions??
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 09-12-2006, 01:18 AM   #5
Packy
Drives: Honda Fit Sport
The Scion xA RS 1.0 had stability control and traction control, so it must not be too hard to just plug in. The Yaris and the xA/xB have the same engine, correct?
Stability control may be a government requirement one of these years (just like airbags), and that would sure save a lot of lives!
Packy is offline   Reply With Quote
Old 09-12-2006, 01:43 AM   #6
pennystocks
i got about 800 more miles to go, i'll have to check in w/ the dealer, see wat they say.
Anybody know if there the same PCM as the scion xA and xB?
Old 09-12-2006, 07:14 AM   #7
Katana
Katana's Avatar
It must be the same, cause the engines are the same, the chip is the same and the transmission is the same.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 05:40 PM
winter control markpeppie General Yaris / Vitz Discussion 11 06-08-2006 08:32 AM
