Old 04-12-2010, 01:28 PM   #37
Originally Posted by rob323 View Post
If the Scangauge is still showing over 13 volts, how can the alternator be "under-charging" the battery?
For a lead acid battery, the optimal charging voltage is 2.26 and 2.36V/cell (which = 13.56 to 14.16 Volts).
Old 04-12-2010, 06:05 PM   #38
MGargano
Drives: 2009 Yaris Hatchback
I'm confused again, since I'm getting 13.5-14.2v, according to the Scan Gauge. Is this too low? Or is it the fluctuation regardless of load that's the problem?
Old 04-12-2010, 08:33 PM   #39
As long as it isn't sagging below that then you are probably OK, but the alternator and regulator should be able to maintain a steady 14.1 at idle.
Old 04-12-2010, 08:41 PM   #40
MGargano
It's definitely not maintaining any kind of steady voltage, at idle or while moving and regardless of the absence or presence of a load.
I guess I'll just swap the alternator and see what things look like with the "new" one.
Old 04-17-2010, 04:43 PM   #41
MGargano
I swapped the whole thing today with an '09 alternator with around 1,000 miles on it ($70). No change in voltage; it continues to fluctuate regardless of load and at idle.
When moving at a decent speed, it generally holds at 14.1v, but at idle and slower speeds, it fluctuates from 13.5-14.1.
Old 04-22-2010, 12:55 PM   #42
MGargano
Well after no change in voltage with the new alternator, I decided to do the "Big 3" upgrade.
I ran 1/0 wire from the alternator to battery +, and chassis/engine to battery -
Zero improvement. Everything is exactly the same- voltage still drops to, and fluctuates around, 13.5 at idle/slow speeds and holds steady at 14.1 as long as I'm moving at a decent speed, all regardless of load.
Hooray for wasting time and money.
NST NonStopTuning Pulley Kits NonStopTuning NonStopTuning 19 11-08-2014 10:23 PM
FS: Blue Pulley Set Shijima Items for Sale by private party 12 09-18-2009 08:34 PM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 10:11 PM
Feeler: NST 10% Underdrive Crank Pulley - Gray Black Yaris Items for Sale by private party 10 04-29-2009 11:24 AM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
