Old 04-18-2010, 10:29 PM   #1
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Custom Intake Manifold + Direct Port Nitrous
What up all , I was able to score that custom intake manifold and direct port nitrous set-up that came from the NOS sema car from" H3llion "on the forum and got it installed and running today . It idles pretty much like stock and hasn't thrown a cel yet and I dont think it will . I've only driven a few miles so far and the car is still getting used to all that extra air lol. The sound from the aem is super loud now and the over-all intake sound is really deep now . After the ecu adjust for the mainfold I think it will be good for a few horsepower but only the dyno will tell. Right now the manifold is jetted for about 50-60 hp across all 4 which is just about the lowest jetting that can be done with a direct port system .
I need to get a "T" to tap the fuel line for the fuel supply . I'm running NOS powershot no2/fuel seloniods and have a NOS purge kit I need to install also and will hit the dyno as soon as all that is done . I plan on polishing the hard lines and need to clean up the wiring a bit and clean everything else too lol .
Old 04-18-2010, 10:45 PM   #2
H3LlIoN
Drives: '09 Yarrrr hatch
haha word brother, glad it's workin for ya!
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 04-19-2010, 07:14 AM   #3
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
that is great, can you do a diy on the fuel tap and the and how u are installing the kit.
cruz-gsr is offline   Reply With Quote
Old 04-19-2010, 08:14 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Cool, but the coolant line doesn't look like it's in the best position now.
Old 04-19-2010, 11:03 AM   #5
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
That's awesome. Can't wait to see the dyno results!
redglare45 is offline   Reply With Quote
Old 04-19-2010, 07:38 PM   #6
blacksandiegovitz
Drives: 08 Vitz
Yeah , I will I plan on using the standard fuel "t-tap" from nitrous express which is just barbs on either side and a -4an male fitting on the "t" part which is connected to the fuel selonoid using the braided stainless line.
Old 04-20-2010, 01:07 AM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
It's rubber.
Looks good.
Old 04-20-2010, 09:16 PM   #8
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Are you going to hit a drag strip with that setup? More interested in that than a dyno.
Old 04-21-2010, 01:14 AM   #9
H3LlIoN
Haha color-matched hotness.
Toyota
Moving Forward
Old 04-21-2010, 07:05 PM   #10
blacksandiegovitz
Drives: 08 Vitz
Just re-torqed the manifold studs and went back to my modified stock air box with k&n drop-in filter and the low-end torque is back and has mad top-end pull with the manifold . I'm pretty sure the ecu has fully adjusted to the new manifold and the car is running and driving the best it ever has . I still need to hook up the seloniods and hit the dyno for some number then bring it out to our local 1/8 racelegal drags !
1nz-fe intake manifold , Xa ... blacksandiegovitz Performance Modifications 32 08-26-2010 01:06 PM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
My Custom Intake RacerFreakXXX DIY / Maintenance / Service 7 12-21-2008 07:32 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
