Old 05-14-2010, 11:51 AM   #37
H3LlIoN
Drives: '09 Yarrrr hatch
Here...it's pic'd in this link...you just need to find it without the rest of the kit.
http://www.corsportusa.com/store/cat...oducts_id=1122
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 05-14-2010, 01:11 PM   #38
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by RacerFreakXXX View Post
I'm going with the perrin fuel rail, as listed in my first post. My main concern are the oil likes and vacume lines and all of that little stuff. Should I tap the oil pan or buy an aftermarket?
Mine Turbo Oil Feed is tapped into the lower block.... just a few inch below the knock sensor position ( behind intake manifold )
Parmas is offline   Reply With Quote
Old 05-15-2010, 09:14 AM   #39
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
I noticed the pn like shape of our oil pan, maybe i'll check on the scion forums and see if any of the guys have luck with the oil pan. Tapping the block scares me for 2 reasons: first I'm worried me or someone I have do it, will screw it up and secondly I'm worried if I ever need to bring the car back to stock, I wont be able to.
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 05-15-2010, 10:26 AM   #40
cdydjded
Drives: Yaris LB Turbo
You have to drill the upper part of the pan. Its not really part of the block. The oil pan itself is to low, you will have oil return problems. I bought the Zage pan to see if the return would work & it does not. There is not way around it.
Old 05-15-2010, 04:26 PM   #41
Tamago
Tamago's Avatar
Drives: UZJ100
ahh yet another turbo thread.
Old 05-15-2010, 04:33 PM   #42
RacerFreakXXX
JDM Fred
from me too, lol... any advice tamango? or are you going to just troll this one?
Old 05-19-2010, 07:07 PM   #43
Tamago
Tamago's Avatar
Drives: UZJ100
it's tamago
and yes, trolling. if you took the time to search, all of your questions have been answered over and over and over and over.
low boost won't require an intercooler.
Old 05-19-2010, 07:18 PM   #44
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
tamagay
Old 05-20-2010, 06:22 PM   #45
Tamago
Tamago's Avatar
Drives: UZJ100
tamagay
Matt Cavanaugh
Old 05-20-2010, 07:02 PM   #46
PETERPOOP
PETERPOOP's Avatar
Joel Geisinger w/ white hair? maybe not...
ps: www.myspace.com/themattcavanaughexperience
Old 05-20-2010, 07:44 PM   #47
LOL @ everything
Old 05-20-2010, 09:36 PM   #48
cdydjded
But it will run alot better with an I/C. Cool dense air is what you want & an I/C creates that for you. There are NO significant drawbacks to an I/C. It only helps with the additional air you are pumping into the engine.
Old 05-20-2010, 09:36 PM   #49
cdydjded
tamagay
Old 05-21-2010, 06:02 AM   #50
Parmas
Parmas's Avatar
There is always a drawback!
Drawbacks of installing an I/C is mainly Boost Lag depending what are the:
- I/C dimensions, Intake and Outake width ports and I/C Brand Quality
- Turbo Specs and Brand
- I/C pipping width and distance between turbo & throttle body
And then there are also...
- Fitment issues or Complications
- Increased Weight and Decreased space into the engine bay
- Surplus total expense to cover all parts and labour
I think that might be all
Old 05-21-2010, 07:04 AM   #51
Tamago
Tamago's Avatar
Drives: UZJ100
proving your gay obsession yet again
Old 05-21-2010, 11:23 AM   #52
cdydjded
Here a link to a article that rebuts most of your points:
http://www.torquecars.com/tuning/aft...ntercooler.php
Read it if you want. If not thats ok. We will agree to disagree on this point.
Old 05-21-2010, 01:49 PM   #53
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
tamagay
Matt Cavanaugh
now now children, if you can't get along, we will just have to put your toys away...
Old 05-21-2010, 02:10 PM   #54
Parmas
Parmas's Avatar
Yes I read the article and this is the most important sentence of all :
"In reality using an intercooler which is too large can hinder airflow so there is an important case of getting the correct size for the application"
I am not saying an i/c isn't important, I just pointed out the drawbacks of having it but that doesn't mean it's not worth it!
