Safety Engineer
Drives: 09 Fit Sport, 07 Yaris Sedan Join Date: Nov 2006
What is the foam on the inside of door panels for
Each door panel has some hard foam with steal on the tips of some of the foam. What is this for? Safety? Structure? I'm working on diy power door locks and would hate to remove it if it's safety related.
2007 yaris sedan |
It make the car float better.
just kidding
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
just a guess, road noise insulation?
やりすぎだ~
keeps the panel from rattling against your door.
Drives: 07 sedan Join Date: Mar 2010
you're a safety engineer and you think that stuff could be structural?? mmmmmk
It is noise insulation. When they pulled out just a little bit in the b-pillar for a TSB, it was noticeable. Its not crazy loud, but it makes the already loud yaris just a little louder. |
Safety Engineer
yes, i am a safety engineer, and i work for a power plant... scared yet?
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
My screen resolution made the "just kidding" not show on the screen and I actually thought you were serious for a second...
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Safety Engineer
lol yeah.
UPDATE: My buddy and I decided to cut the foam. It seems like if you want DIY power door locks, you will need to cut the foam. From all of the comments, the road noise insulation comment rings best, but I am not sure what info. the comment is based on. So, future DIYers, cut at your own risk... RELATED FINDING: I looked at the stripped door area and found a very likely issue for power windows DIY. The metal-stick that the manual power window handle attaches to that you would instead attach the power window motor to seems to sticks out of the door panel too much to make a flush install (read: easy) of power windows... so do your research before attempting power windows on our sedans. Last edited by homerj; 07-11-2010 at 01:08 AM. |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| Black Depo Headlights Inside Peeling | ruimond | Cosmetic Modifications (Exterior/Interior) | 5 | 12-11-2009 09:01 PM |
| Back door won't open from the inside ?! | bnther36 | General Yaris / Vitz Discussion | 14 | 10-20-2009 02:04 PM |
| stock tire inside? | PhasedWalker | Photo-Video-Media Gallery | 4 | 06-24-2009 09:18 AM |
