Old 06-22-2009, 01:14 AM   #1
PhasedWalker
PhasedWalker's Avatar
Drives: yaris sedan aero pkg
stock tire inside?
anyone has a picture of stock potenza re92 185/60r15 stock tires pictures? maybe a picture that shows the inside wall. or some pictures of a diy patching with that tire from inside, want to get a idea of the structure b4 trying??
PhasedWalker is offline   Reply With Quote
Old 06-22-2009, 10:10 PM   #2
Yaritz
Drives: '09 Polar White Yaris
If you plan on patching a tire on the sidewall...don't. It is the weakest part of the tire when damaged. The kind of plug that a normal consumer can buy easily is the worst possible kind as well. It forces you to stretch the hole past the size it already is and severely damages the nylon cords and steel belts. My recommendation would be to replace the tire, as a tire plugged in the sidewall is at a much greater risk of a blow-out. I also want you to know this is not just my opinion with no facts to back it up. I was a tire tech for four years at Discount Tire, Tires Plus, and NTB/Tire Kingdom. If I seem like a dick, my bad. I just don't want anyone to get hurt.
Yaritz is offline   Reply With Quote
Old 06-22-2009, 10:18 PM   #3
1NZYaris1
1NZYaris1's Avatar
+1 on that , buy a new tyre ,cheaper and safer in the long run.
Old 06-24-2009, 08:27 AM   #4
PhasedWalker
damn more spending :( any cheap place to get tires in toronto area? :O
Old 06-24-2009, 10:18 AM   #5
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I've had plugs in the middle of the tread work well for years, but they can suddenly start leaking again when you've forgotten about them. You can't plug in sidewalls, and if it's in the outside rib of the tread it's a bad idea. If you've got to fix a puncture, a patch on the inside's better than a plug, and replacing the tire's always best of course. Sometimes you've just got to get going again quickly and on the cheap, so I always keep a plug kit handy.
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 10:44 AM
Has anyone weighed stock rim w/o tire 50MPGDream Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 08-16-2007 04:56 AM
FS: Stock 15" RE92 tire GabL Items for Sale by private party 9 07-02-2007 03:20 AM
stock tire pressure... argylesocks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-16-2006 01:28 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
