Old 07-18-2010, 10:59 PM   #1
Brian
Brian's Avatar
Kido brakes installed
I haven't had a chance to completely test the brakes out yet. Just a couple laps around the block. Here are the pics.
OEM size rotor vs Kido 286mm
I had to trim the dust shield to clear the caliper bracket
Brake lines
Done
Old 07-18-2010, 11:26 PM   #2
That looks great, Brian, I'll be getting more in stock shortly.
Old 07-19-2010, 12:38 AM   #3
big lo
big lo's Avatar
Drives: 2007 VIOS
Awesome stuff Brian, looks good, how long did this project take, and how does it feel compared to the stock brakes? Holla at me.
Old 07-19-2010, 03:03 AM   #4
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
That is freaking NICE bbk there!!!!!
Brian, do you have any 15inch aound...? If so hope you can test fit one of the 15 into your front.
I seriously considering the Kido from garm. Although as mentioned it can clear 15inch rims, but i just need to confirm this statement as bbk like this involde with huge cost.
btw mine is SSR Type-F 15x7
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 07-19-2010, 11:37 AM   #5
Brian
Brian's Avatar
I don't have any 15's but by the way it looks with my 16's, it should easily clear 15's.
Old 07-19-2010, 11:54 AM   #6
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
Garm or Brian, can you tell me how much these are. I would love to do this. I have been looking at the Endless upgrade for the Yaris, but this kit looks really nice too. Love the color of the calipers.
Old 07-19-2010, 01:41 PM   #7
Brian
Brian's Avatar
I think Garm still has 1 kit left with red calipers and bigger rotors. Im sure these will perform just as well as the Endless or Project Mu kits.
Old 07-19-2010, 02:19 PM   #8
They're also 6-pot as well, right? (The other kit that Garm has left as of right now)
Old 07-19-2010, 03:38 PM   #9
YarisSedan
Drives: 08 Yaris Sedan
Looks like you put the rotors on the wrong sides. I think the drivers side rotor should be on the passenger and vise versa. I could be wrong but i believe the slots should be rotational facing forward so they channel the air and brake dust not opposite. Simular to directional tires channel water.
Old 07-19-2010, 03:43 PM   #10
I don't think the direction of the slots matter. It's the direction of the vanes that matter.
Old 07-19-2010, 03:48 PM   #11
*Pictures from Garm's thread on MI
This is the one that Brian has, I think. See how the vanes are vertical (at least that's what it looks like to me)? Since they're vertical, it won't matter which way the slots face.
I believe this is the bigger of the two BBKs. It has directional vanes (again, looks like it in the pic), and should be installed with the slots leaning forward like how Brian has them (since the vanes have to be leaning backwards, but someone correct me if I'm wrong with all of this).
Old 07-20-2010, 02:13 AM   #12
correct, it doesn't matter.
Old 10-25-2010, 06:43 PM   #13
auxmike
auxmike's Avatar
How much does this set cost then??
Are rotors and pads hard to find?
Rear Drum brakes bankrobber DIY / Maintenance / Service 0 04-17-2010 11:39 PM
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 12:04 AM
A few questions about suspension, tires, and brakes. supmet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-02-2009 04:55 PM
Weird question about my brakes brainless twit General Yaris / Vitz Discussion 8 01-22-2009 10:59 AM
Brakes Geelmeel General Yaris / Vitz Discussion 16 06-29-2007 07:58 PM
