Kido brakes installed
I haven't had a chance to completely test the brakes out yet. Just a couple laps around the block. Here are the pics.
OEM size rotor vs Kido 286mm ![]() ![]() I had to trim the dust shield to clear the caliper bracket ![]() Brake lines ![]() ![]() ![]() ![]() ![]() Done ![]()
That looks great, Brian, I'll be getting more in stock shortly.
Awesome stuff Brian, looks good, how long did this project take, and how does it feel compared to the stock brakes? Holla at me.
![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
That is freaking NICE bbk there!!!!!
![]() Brian, do you have any 15inch aound...? If so hope you can test fit one of the 15 into your front. ![]() I seriously considering the Kido from garm. Although as mentioned it can clear 15inch rims, but i just need to confirm this statement as bbk like this involde with huge cost. ![]() btw mine is SSR Type-F 15x7
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
#5 | |
Right beside you, wave
Drives: 08 PBM Yaris Sedan Join Date: Oct 2008
Garm or Brian, can you tell me how much these are. I would love to do this. I have been looking at the Endless upgrade for the Yaris, but this kit looks really nice too. Love the color of the calipers.
![]() 2008 Toyota Yaris Sedan. Pacific Blue Mica. Custom vinyl eyebrows, color matched interior trim pieces, Vios lip spoiler, 17" Maas rims 2010 Scion xB 7.0 Release Series. 1535 of 2000. Murasaki. Stock with TRD springs. |
I think Garm still has 1 kit left with red calipers and bigger rotors. Im sure these will perform just as well as the Endless or Project Mu kits.
They're also 6-pot as well, right? (The other kit that Garm has left as of right now)
Looks like you put the rotors on the wrong sides. I think the drivers side rotor should be on the passenger and vise versa. I could be wrong but i believe the slots should be rotational facing forward so they channel the air and brake dust not opposite. Simular to directional tires channel water.
#10 | |
*Pictures from Garm's thread on MI
This is the one that Brian has, I think. See how the vanes are vertical (at least that's what it looks like to me)? Since they're vertical, it won't matter which way the slots face. ![]() I believe this is the bigger of the two BBKs. It has directional vanes (again, looks like it in the pic), and should be installed with the slots leaning forward like how Brian has them (since the vanes have to be leaning backwards, but someone correct me if I'm wrong with all of this).
correct, it doesn't matter.
How much does this set cost then??
Are rotors and pads hard to find?
Never take eyes off opponent - Bruce Lee |
| Rear Drum brakes | bankrobber | DIY / Maintenance / Service | 0 | 04-17-2010 11:39 PM |
| Metal scratching from brakes | alt_k1ll3r | DIY / Maintenance / Service | 16 | 02-11-2010 12:04 AM |
| A few questions about suspension, tires, and brakes. | supmet | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-02-2009 04:55 PM |
| Weird question about my brakes | brainless twit | General Yaris / Vitz Discussion | 8 | 01-22-2009 10:59 AM |
| Brakes | Geelmeel | General Yaris / Vitz Discussion | 16 | 06-29-2007 07:58 PM |
