Old 08-19-2010, 04:53 PM   #19
Zamal7591
Drives: TRD turbo vitz
I'll try to check it tomorrow , Thanks!!! the ECU is 1 NZFE T , Do you think its the same!!!
Zamal7591 is offline   Reply With Quote
Old 08-19-2010, 04:57 PM   #20
Zamal7591
I'll check it , Thanks , Do u think its the same as the ECU 1 NZFE T????
Old 08-19-2010, 05:00 PM   #21
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Should be.
Old 08-19-2010, 05:06 PM   #22
Zamal7591
Btw can i get a picture of it , please?!!!
Or a plan?!!!
Old 08-19-2010, 05:22 PM   #23
ali077
TRD TURBO
Drives: TRD VITZ TURBO 2003
but the arrangement of the wires on my ECU is completely different as mine is a turbo. its the same 1nz-fe engine but with factory fitted turbo. the code of my ecu is 1nz-fet. its does have 4 connector and does have a purple wire with white tracer but not in connector b and pin 17 as stated. shall ill try to connect it to the wire though?
btw thx for ure help. much appreciated.
Originally Posted by Bluevitz-rs View Post
No need for the PMs...
It's a purple wire, but I don't have my EWD on hand to tell you what connector... I'll see If I can find it.
Edit: ok found it. I have a '04 manual, so as long as you have a 4 connector ECU it should be the same. It's a purple wire with white tracer, pin 17, connector B.
ali077 is offline   Reply With Quote
Old 08-19-2010, 09:05 PM   #24
Bluevitz-rs
On my EWD, it's the only purple with white tracer on the ECU, so if that's the only one on yours, then it would be safe to assume it's the same.
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Engine intake air flow not smooth on certain speed and gear? ammophobia DIY / Maintenance / Service 3 07-17-2009 03:31 AM
