Old 06-04-2010, 07:24 PM   #1
H3LlIoN
Drives: '09 Yarrrr hatch
Engine Speed Sensor Location?
Where is it? I'm talking about the RPM sensor that send the speed data to the ECU...Or even better, does any one have a map of all of the sensor locations on a 1nz? thanks,
- H
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 06-04-2010, 11:40 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It's under the backside of the pulley. Look for a big black connector with tape on it.
Old 06-11-2010, 12:37 AM   #3
ddongbap
Originally Posted by tech101 View Post
I am a new member here. But pls visit our homepage URL through my Signature and URL Link....
I tried. Why did i see porno?
Old 06-11-2010, 12:38 AM   #4
tomato
tomato's Avatar
sorry, better luck next time !
Old 06-11-2010, 09:39 AM   #5
H3LlIoN
Thanks Cdy...here is the info for the next guy:
"The Crankshaft Position (CKP) sensor system consists of a CKP sensor plate and a pickup coil. The sensor plate has 34 teeth and is installed on the crankshaft. The pickup coil is made of wound copper wire, an iron core and magnet. The sensor plate rotates and, as each tooth passes through the pickup coil, a pulse signal is created. The pickup coil generates 34 signals per engine revolution. Based on these signals, the ECM calculates the crankshaft position and engine RPM. Using these calculations, the fuel injection time and ignition timing are controlled."
And location:
Toyota
Moving Forward
Old 06-11-2010, 10:12 AM   #6
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
And location:
Does this sensor relates to the Crank Trigger?
Does the crank trigger is 34 on our 1NZFE?
Old 06-11-2010, 06:29 PM   #7
H3LlIoN
I think you mean:
A) Is this the sensor same as a crank trigger? (yes)
B) Is the signal 34 pulses per revolution? (yes)
Toyota
Moving Forward
Old 06-16-2010, 07:40 AM   #8
Parmas
Parmas's Avatar
I don't know maybe the image is illusrated wrong since mine the crank sensor is at the lower left of the engine and not in the middle as shows the image.
See below attachment
Can you confirm is the same sensor?
Old 06-16-2010, 09:02 AM   #9
Bluevitz-rs
You're view the image in the wrong contexts. The view shows the sensor by looking through the motor and is indeed in the lower left corner of the block.
Old 06-16-2010, 03:00 PM   #10
Parmas
Parmas's Avatar
Thanks better sure than disappointed
Old 06-16-2010, 09:07 PM   #11
H3LlIoN
Sry I'm just getting to this...Bluevitz is correct. You need to be thinking in terms of X-ray vision.
Toyota
Moving Forward
Old 08-18-2010, 02:59 PM   #12
ali077
TRD TURBO
Drives: TRD VITZ TURBO 2003
i need to connect a vehicle dynamic processor from pioneer. which of these sensors can i get the vehicle speed signal from?
ali077 is offline   Reply With Quote
Old 08-18-2010, 11:37 PM   #13
Bluevitz-rs
The Vehicle speed sensor comes out'a the transmission.
Old 08-19-2010, 02:38 PM   #14
Zamal7591
Drives: TRD turbo vitz
May I know what is the colour of the wire and where it si found exactly( Diagram or picture please)
Zamal7591 is offline   Reply With Quote
Old 08-19-2010, 04:28 PM   #15
Bluevitz-rs
I replied to your PM, what year is the car?
Old 08-19-2010, 04:35 PM   #16
Zamal7591
its a 2003 Vitz TRD Turbo
Old 08-19-2010, 04:38 PM   #17
Bluevitz-rs
No need for the PMs...
It's a purple wire, but I don't have my EWD on hand to tell you what connector... I'll see If I can find it.
Edit: ok found it. I have a '04 manual, so as long as you have a 4 connector ECU it should be the same. It's a purple wire with white tracer, pin 17, connector B.
Old 08-19-2010, 04:53 PM   #18
Zamal7591
I'll try to check it tomorrow , Thanks!!! the ECU is 1 NZFE T , Do you think its the same!!!
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Engine intake air flow not smooth on certain speed and gear? ammophobia DIY / Maintenance / Service 3 07-17-2009 03:31 AM
