Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 09-10-2010, 05:09 PM   #1
eazyace
Drives: Toyota Yaris 3dr
A really good sway bar
Want to buy a rear sway bar. The bigger the better.
eazyace is offline
Old 09-10-2010, 05:34 PM   #2
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
microimage sells ultra racing 23 mm. fattest available.
free shipping.
bolts right on, hardware included. works great.
see user "Cali yaris" if you wanna know more, or go to
http://shop.microimageonline.com/Ult...R-AR23-100.htm
127.0.0.1 is offline
Old 09-10-2010, 07:37 PM   #3
RedRide
RedRide's Avatar
Yes, I have the Microimage 23mm bar and highy recomend it. You need to look no further.
RedRide is offline
Old 09-11-2010, 01:14 AM   #4
eazyace
thanks for the replies. I will look into it. I would really like to improve the handling on this car. Will the bar be enough. I come from a 07 vw gti with stock suspension. Will it compare or will I need to do more? Thanks for the replies
eazyace is offline
Old 09-11-2010, 02:11 AM   #5
sleey0
Drives: 2008 Yaris LB
Sway bar on stock suspension isn't going to cut it.
For the least amount of $, go with Tokico HP shocks and a set of Micro Image springs.
Setup for less than $500.
sleey0 is offline
Old 09-11-2010, 09:45 AM   #6
127.0.0.1
sway bar is the FIRST thing to install. then decide if you want to change other
stuff.
it has the most effect for dollar ratio...and it is the cheapest and easiest to install.
that is all I stuck on my Yaris and I was blown away by the way it
completely changed the car from a marshmallow in corners, to rather sporty
Old 09-11-2010, 11:55 AM   #7
sickpuppy1
Drives: 2010 Yaris Sedan
stuff.
I gotta agree 100%. I have no springs or shocks other than stock so far, but I did put on the 19mm sway from micro image, and the difference from bone stock is amazing. At first I wasn't sure what to expect, but what I discovered in short time, is 1st, the ride hasn't changed at all,2nd, when I do the on/off ramp thing or twisty roads, it takes a slight lean, the bar takes effect and it just stays planted. The rear end stays flat and it goes thru corners so much more stable. The side winds on the highway don't push the body around near as much as it used to. Best money I've spent on a car in a long time. I wish I had gotten the 23mm to check it out, but don't regret the 19 at all!! And this is with the OEM Goodyear tires which makes it all the more impressive in my eyes!
I would suggest doing this first and get a feel from there how much further you want to go, and what your goals are. I'm in a 10 sedan, so it is not as tail happy as a LB might be. And realize the shock/spring combo will effect ride quality, how much depends on what you get and how much that means to you.
sickpuppy1 is offline
Old 09-11-2010, 08:22 PM   #8
eazyace
thanks for the replies guys. I am going to take the plunged on the sway bar and then decided if anything else is necessary.
eazyace is offline
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 03:08 AM
Rally Sway Bar setups Bill@WORKS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 09-23-2009 10:01 PM
front sway bar question thom25 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-25-2009 08:54 PM
Got new TRD sway bar! caineroad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-24-2009 11:55 AM
Question about Sway Bar! Ton Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 01-06-2009 04:31 PM
