Old 08-24-2009, 10:12 PM   #1
thom25
Drives: yaris
front sway bar question
Anyone know the size of the stock front sway bar for a 2008 yaris HB? If I wanna change the front sway bushing to polyurthene, what size should I purchase? Thanks
thom25 is offline   Reply With Quote
Old 08-24-2009, 10:25 PM   #2
Must be smaller than 19mm since after market ones are 19mm. However, I'm sure someone can give you a specific answer.
Old 08-24-2009, 11:05 PM   #3
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
quick search yielded this:
http://www.yarisworld.com/forums/sho...light=sway+bar
and its 23mm
Old 08-25-2009, 12:00 AM   #4
Whoa, I guess I neglected the word front. LOL! Sorry about that. My post was in reference to the REAR sway bar. Sorry again.
Old 08-25-2009, 12:10 AM   #5
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
i think our cars dont come with a rear? so anything is an improvement lol
im curious to see how the trd will affect my rear, i believe its 23mm
Old 08-25-2009, 12:11 AM   #6
TRD rear sway bar is 19mm.
Ultra Racing I carry comes 19mm or 23mm
Stock front sway bar is either 22m or 23mm. I carry AOE which is 24mm.
Old 08-25-2009, 07:58 AM   #7
MUSKOKA800
MUSKOKA800's Avatar
The addition of a rear anti-sway bar to the Yaris makes a huge difference in handling and stability. DO IT!
Old 08-25-2009, 05:37 PM   #8
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
from night to day
Its a Chao!!!
Old 08-25-2009, 05:39 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
if you autocross, avoid a larger front swaybar.
Old 08-25-2009, 07:29 PM   #10
Yes, a larger front sway bar on a fwd will induce more understeer, correct?
Old 08-25-2009, 07:45 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
not necessarily. the real problem with a huge front swaybar on an open-diff car is your corner exit is destroyed by inside wheel lift (spin) throwing away your ability to put power down mid turn or even after the apex.
on high speed courses this should not be a problem though, as momentum carries you thru the "front wheel lift" portions of the corner (as long as you know how to drive)
Old 08-25-2009, 07:50 PM   #12
kngrsll
Apexing Egg!!
kngrsll's Avatar
so you think if you had an LSD that a bigger front rear bar would help?
the last track i went to, CMP, had more low speed corners. REALLY needed an LSD
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 08-25-2009, 07:52 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
yes, LSD's should come with free swaybars (dont' we wish front swaybars came with free LSD's? )
Old 08-25-2009, 07:54 PM   #14
Ah, I see. I didn't know that. Thanks for sharing.
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Stock Front Sway bar kngrsll Tracking, Racing, Auto-X Forum 4 07-04-2009 07:01 PM
Yaris 24mm Front Sway Bar bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-09-2009 02:33 PM
FS: NEW C-One Front Sway Bar & 4-Point Brace NEW LOWER PRICES! 03Z33 Items for Sale by private party 1 06-06-2009 01:29 AM
Question about Sway Bar! Ton Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 01-06-2009 03:31 PM
