![]() Drives: 2010 5-door hatchback Join Date: Apr 2010
Hi Yaris-driving friends!
I just noticed a deep scratch (about 5 inches long) at the bottom of my Yaris' front bumber. It removed all the paint thru to the black-colored plastic (my Yri is greenish silver I think it's called something like "aqua"). Any idea what the best way to go about repairing this? I looked for a touch-up tube at Kragen's - there were some Toyota colors but not mine ("silver" was the closest I saw there). Can I get the original color anywhere? Thanks Michael |
![]() Drives: 09 Yaris_Red LB Join Date: May 2010
Try fix-up.com. They make colors based on paint code and VIN number. Does an awesome job on our absolutely red!
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
You should be able to get a vile from the dealer for only about $8. Your paint code I believe is 777 (Jade Sea Metallic) according to this: http://www.yarisworld.com/forums/showthread.php?t=22582
Also, since the plastic is exposed, I would very lightly sand it first with 500 grit so that the touch-up paint doesn't flake later and you have to do this again.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
Croaker, SilverBack, THANKS so much for your valuable help. I will look at both fix-up.com and ask the dealer. What is a vile?
Thx |
Joey
The touch-up vile is a little 1/2 oz. container of paint about the size of a fat crayon. They usually come with a pen and brush built into the cap. It should be more than enough to cover a 5-inch long paint gash. Hope this helps.
#6 | |
Vile?
![]() Thank you |
I checked the right codes thru the great references you guys provided (again, THANKS for those helpful responses and links).
I found on this ToyotaReference web site and by going back to "buy new car" web sites (like autos on Overstock.com) that my Yaris' color actually is "Meteorite" metallic. Not sure where I got the "jade" thing in my mind. Anyway, I got my color code: 1FB (it's a 5-dr hatchback). Thanks to your help I am making great progress towards repairing this scratch! |
#8 | |
Joey
. Good luck with the fix.
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
Tell you the truth, doing a touch up is realy hard cause I did mine and the touch up paint look darker,rough and dull/couldy
OK, so I got the touch-up tube. I repainted over the scratch. The color matches well but it's not flat and smooth, you can still see the scrtatch, it's just the same color as the rest of the bumber.
Should I sand it first before retouching? Any instructions or video on how to do it? Thanks Michael |
What you should do is get a injection type needle. Like the kind at hospitals. Then draw a small amount from the bottle and fill in the scratch. That way you only get paint in the scratch. Once it drys add some more to build up the layer till its even with the surrounding paint. Then use something like meguires ultimate compound on the scratch and area around it to blend it in. Using the brush in the bottle just makes a ugly blob and usually makes the scratch more noticeable.
#12 | |
Hoping that I'd luck out when I noticed a few chips on my bumper, I talked to my dealer and he just ordered one for me from the parts department. Just have to pick it up from the dealership when I'm there next. Maybe if you ask real nice you can get hooked up too!
| Tags |
| bumper scratch repair |
| Deep scratch on rear door-HELP! | Eatoman | Wash, Wax, Detailing, Exterior Repairs | 51 | 02-19-2011 02:31 PM |
| WHITE Yaris paint touch up + silver dashbaord scratch repair | marcus25 | Wash, Wax, Detailing, Exterior Repairs | 1 | 08-26-2010 01:11 PM |
| Deep scratch removal | regal | Wash, Wax, Detailing, Exterior Repairs | 8 | 06-19-2009 12:04 PM |
| Bumper repair | sliiice | Cosmetic Modifications (Exterior/Interior) | 11 | 03-30-2009 08:13 PM |
| Under bumper scratch | Lowfront | Wash, Wax, Detailing, Exterior Repairs | 8 | 09-12-2006 01:58 PM |
