#19 |
Hooch Brewer-Shine Sipper
So, in CTScott's picture above, as long as the wires from 3 is connected to 13 with a splice, the fog lights will come on with the park lights?
#20 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Yep.
Just make sure to wire the rest the oem way and you are set. |
#21 |
Correct. And Ray's (1NZ's) pigtail pictured above, lets you do the mod without cutting into the OEM wires. With his you pop the pins, connect them to his one pin connectors, and the splice happens within his harness.
#22 |
I appreciate the help. I'm not installing the fog lights myself. A custom shop is doing it, and although they say they've done these before, I printed out all these instructions to make sure the lights get wired up to the parks. I'm getting the fogs installed at the same time I get 3 little dings fixed.
Although the separate switch is nice, it would never work for me. I'd be calling for a jump all the time (leaving them on).
#23 | |
http://www.yarisworld.com/forums/sho...diy+headlights |
#24 | |
![]() Drives: 2010 5 door yaris Join Date: Feb 2011
Question. Who is Garm and where can I buy this latest kit your talking about? Is this it? http://shop.microimageonline.com/Fog...-foglights.htm |
#25 | |
#26 |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
By "fog lights on with the parking light switch", that means they are on when the stalk is in the middle position, off when in off position, and off in the running light position? Or do the fog lights also go on with normal running lights on (stalk in "night"/running lights position)?
I'm on the fence about fog lights pending a proper way to get a switch solution for them. |
#27 |
Tagging along
#28 | |
My Box and Her Egg
Drives: 05' Scion xB / 08' Yaris 3dr Join Date: Sep 2006
So all I do to make them come on with the parking lights is connect the yellow wire to the white wire? Can I just use a small piece of wire with 2 wire taps to connect them? Last edited by bB2NER; 02-19-2011 at 07:36 PM. |
#29 |
Do the park light mod instructions come with the kit as well as the jumpers?
Just ordered mine. |
#30 |
boydstir
hi is there a h.i.d fog lights i want to match the light color blue with my h.i.d head lights ? please help also looking for that wire harnes adapter to run on stock light controll no need for switch in console help help
#31 |
boydstir
if a set is out there for sale does anyone know ware to get it ? please advise
#32 |
what color are your headlight HID's?
blue is 10000k to 12000k usually. could get a set of H11 to match.
#33 |
boydstir
yes they have a blue tint to them do you have them for sale and i want to run them off the factory light controll stack dont want to run any more wires thru the firewall right now thanks for any help you can give me
#34 |
boydstir
just found out they are 8000k does this help my h.i.d. power paks are up in the fender well back in ware the from window piller post come over the top of firewall i dont like looking at extra non factory parts if possible
#35 |
boydstir
had to ask the guy i purchased the lights from got the info ready to buy matching fogs
#36 |
You need a foglight kit + an HID kit, right?
| Has anyone tried taping into the parking lights for fog light installation (safe?) | YarisSedan | DIY / Maintenance / Service | 14 | 03-20-2010 04:49 AM |
| 2009 HB fog light installation | rbell | DIY / Maintenance / Service | 3 | 06-17-2009 09:16 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
