#1 |
![]() Drives: 2009 Yaris HB Join Date: Jun 2009
2009 HB fog light installation
Ordered a set of fog lights from Micro Image. Is it really 10 pages of instructions to install these? I thought the '09 came "pre-wired". Removing the front bumper and the underside of the steering column?
The pre-wiring saves you from having to pull a wire through the firewall and lets you use the stock fuse slot and relay slot. To mount them you still have a little bit of labor (and wiring) to do.
#3 |
Thanks. I'm capable of the installation. I just remember when I used to drive Dodge vehicles, the cars were actually pre-wired. If you pulled the fog light cover off, there was a connector right there. The harness was already in. Same with the radio. If the car didin't have one, the harnes was still behind the plastic plate. It was literall plug n play. Seems like the cars today would already be wired for options, just to keep the manufacturing process consistant.
#4 |
If your talking about the factory PDF , it shows you how to remove body
parts to install the lights , and where and how to plug everything in . So unless you know what you are doing then yes they are inportant . unless you have done it before, then you will know all the short cut's |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Part #s for Fog Light install? Can anyone who works for Toyota confirm? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 73 | 12-23-2010 06:15 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 09:25 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 11:42 AM |
