Old 09-25-2010, 10:01 PM   #37
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Originally Posted by yaris2010RS View Post
what were the terms of getting it replaced under warranty?
Not sure I follow.
I brought it in because the clutch was chattering quite badly. They said it needed to replaced and it would be covered under warranty. I asked if I could pay the difference between the OEM clutch and the TRD unit, and they said OK.
Old 09-25-2010, 11:17 PM   #38
sleey0
Drives: 2008 Yaris LB
Good to know and THANKS!
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 09-26-2010, 02:41 AM   #39
yaris2010RS
yaris2010RS's Avatar
Not sure I follow.
oh it was chattering. lol, i wasnt sure if u wore it out and got it done under warranty.
Old 09-26-2010, 08:30 AM   #40
Dorkinheimer
Dorkinheimer's Avatar
Drives: Yaris 2007 *manual*
Every manual car I owned, was hard to put in reverse. All you have to do is "advance" an inch and then put it into reverse, then it's goes in easily.
Dorkinheimer is offline   Reply With Quote
Old 09-26-2010, 09:10 AM   #41
djct_watt
Drives: 2010 NCP91 5spd
That's what she said.
Old 09-26-2010, 11:14 AM   #42
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Old 09-26-2010, 12:34 PM   #43
sleey0
What is clutch chatter?
And is it normal for the clutch to not disengage the engine at high speeds?
For ex I will be doing 70 in 5th gear. When I put it into neutral that cars is still revving until about 60mph when thne it drops into a neutral gear normal low rpm.
I assumed it has something to do with DFCO.
Clear with my desctiption?
xbgod - 9/23/2010
Old 06-23-2017, 12:55 PM   #44
soldiersvejk
Drives: 2009 Toyota Yaris Sedan
Originally Posted by eazyace View Post
Just curious but do any of you have problems when shifting to reverse? Sometimes I get a weird noise when shifting to reverse and sometimes it's harder than other times even though the clutch is pressed all the way. Any inputs?
Please see this video:
"Manual Transmission: Avoid Reverse Gear Grind"
https://www.youtube.com/watch?v=KN5fgRFTqys
The reason is simple: the reverse gear does not has a synchronizer. Therefore, you can simply put it in the 1st gear to synchronize, then shift into the reverse gear. I have tried this trick, and it works!
soldiersvejk is offline   Reply With Quote
Old 06-23-2017, 01:06 PM   #45
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Any gear other than 2nd will do the trick, right?
On Instagram
On Wheelwell
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
TRD Clutch put in: Break-in noise? Thirty-Nine Performance Modifications 12 02-11-2010 08:16 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
