Old 09-30-2010, 11:50 PM   #1
Jenn103
Drives: 07 yaris sedan
Engine sounds sick=(! help
Hi guys, I am new to this forum. I own a 07 yaris (sedan). I havent had too many issues before this...but i need your help now.
When I drive, my engine sounds like its revving way higher than it is. My boyfriend says its more like a vibrating sound that gets higher as the speed gets higher. He says it doesnt matter what gear its in. He also says the sound ..sounds like its coming from the front wheel area. Its kind of scary, I feel like the engine will blow any second as I do alot of highway driving to and from work. When I go up to 120, the car sounds soooo loud its crazy. to me, it doesnt sound that bad when I am in residential and going like...40. but anything after that it starts going all crazy. Sorry im not good at explaining sounds or mechanical problems but if it sounds like something any of you have experienced advice would be super helpful!
Thanks, Jenny =)
Jenn103 is offline   Reply With Quote
Old 09-30-2010, 11:54 PM   #2
johnny_vitz
Drives: 2005 Toyota Echo
Thanks, Jenny =)
Does the noise change with engine speed (R.P.M) or with vehicle speed? It almost sounds like a bad wheel bearing if I understand correctly. Hope this helps, and welcome
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 09-30-2010, 11:58 PM   #3
Jenn103
The noise changes with vehicle speed. If I put the car in neutral as it is moving, the sound remains the same!
Old 10-01-2010, 12:02 AM   #4
sleey0
Drives: 2008 Yaris LB
Wheel bearing.
Is it a humming sound that gets loud on the highway? If so, bearing:)
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-01-2010, 12:07 AM   #5
Jenn103
Yep, sounds about right. I will replace those this weekend! Thanks both of you for you help!!
Old 10-01-2010, 12:10 AM   #6
sleey0
Labor intensive,but the part should be cheap-ish.
xbgod - 9/23/2010
Old 10-01-2010, 12:22 AM   #7
johnny_vitz
Are they still the same style as the echo that need to be pressed out?
Jenny- If so, you will need access to a hydraulic press to get them in/out of the hub. Should only be one of them that's gone bad. Easiest way to check is with a stethescope on a hoist.
Old 10-01-2010, 02:16 PM   #8
AdamMc
Drives: 07 yaris
This may sound silly but: if someone were to DIY wheel bearing replacement and they didnt have access to a press - could you use some other method to get the bearings in/out? even if it's not the recommended way?
ie: lube up as much as you can and use blocks of wood + a vice and attempt to force the bearing back into the assembly that way?
AdamMc is offline   Reply With Quote
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
engine question... (2ZR-FE and 2ZZ-GE) Avia General Yaris / Vitz Discussion 5 12-24-2010 09:16 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 08:11 PM
Gearbox/diff squeak, poor engine braking Kiz DIY / Maintenance / Service 8 08-01-2009 10:35 AM
