Old 10-07-2010, 07:47 PM   #1
sleey0
Drives: 2008 Yaris LB
Head Studs
Can anyone get a part number from toyo or point me in the right direction for a set.
I can find anything online for 1NZFE head studs.
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-07-2010, 08:35 PM   #2
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Found this http://www.scikotics.com/forums/show....php?p=2201506
Mabey PM Aras and see if there is any updates ?
Old 10-07-2010, 11:08 PM   #3
sleey0
Thanks but Garm confirmed ARP never made them.
I am just looking for the darn Toyota OEM part number at this point.
Some company in Spain makes them but I have no idea who or what the name of the company is (or quality for that matter).
So, Head Stud OEM part numbers anyone?
TIA
xbgod - 9/23/2010
Old 10-07-2010, 11:19 PM   #4
sleey0
Ok check the pic. Is the "17159 BOLT, STUD (FOR MANIFOLD TO CYLINDER HEAD)
90126‑08026 1NZFE..NCP91; INTAKE SIDE 2 $3.38
90126‑08037 1NZFE..NCP91; EXHAUST SIDE 2 $5.35
What I need? I am not sure if this is the right head stud. 2 for cool side and 2 for hot?
xbgod - 9/23/2010
Old 10-08-2010, 12:33 AM   #5
I think there are 10 total.
Old 10-08-2010, 03:43 AM   #6
xbgod
Drives: "Burning It Down GTX2860RS XB"
Call the toyota parts dept. Their 110.00 for the set. They're yield 90 deg. So you need a new set everytime you remove them.
This is not a hard part to find.....Are you serious.
Also if your gonna take the whole motor down then you may as well buy the complete seal and head bolts kit for the entire motor. I've bought 3 of them from Toyota.
Just call toyota get the kit and be done.
You do not warrant a custom head stud kit.
Heres how this plays out:
Golden Eagle sleved block = at my cost 1,150.00 (thats just sleeving)
CNC block for custom head studs= 350.00
Toga main bearing race set= 80.00
Polish crank= 110.00
total unassembled = 1,690.00
Now since Golden Eagle does not assemble this motor we now have to do this:
Get the block noched to clear Crower rods = What ever price someone wants to charge you. My cost = free did it on a Bridgeport machine at the shop.
File fit rings for pistons
Assemble all parts Rods/ Pistons crank check for clearences ( you may want to use blue dyecom for this, it will visually let you know if your not clearing)
Once completely satisfied ensure torque spec are meet.
Oh yeah, rods = 800.00
Arias pistons = 800.00 for another 1,600.00
You are now at 3,200.00 without the charges of the above mentioned stuff. This is because you don't know how long it will take to assemble or get proper fitment. So for GP we will say 1,600.00 which will be about average
now your at 4,800.00 and haven't even gotten to the head or assembly of it or timming of the motor.
This is all the things you need to account for. Almost 5G's and not even close yet.
XBG
xbgod is offline   Reply With Quote
Old 10-08-2010, 08:44 AM   #7
sleey0
Got it.
What if I just want to change rods and not pistons? To not fuck with the C:R - just to beef up the weakest link?
Is that sound reasoniing for 12psi?
xbgod - 9/23/2010
Old 10-08-2010, 10:40 AM   #8
sleey0
Well toyota keeps telling me there are only 2 head studs I don't know what the heck is gone on
xbgod - 9/23/2010
Old 10-08-2010, 10:44 AM   #9
^ Did you look at the technical manual (with diagram) that Thomas publishes on both this site and MI? A visual would help you.
Also, think about the head, sitting on the motor. It's pretty obvious that two bolts are not going to hold it on securely.
Old 10-08-2010, 10:47 AM   #10
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
The picture you listed does not have head bolts themselves. Those are just for intake and exhaust manis.
http://www.importperformanceparts.ne...s-etoyota.html
Ajusas sells headbolts, I do not know if they are reusable. About half way down the page.
Old 10-08-2010, 11:24 AM   #11
Here's what the EPC shows:
Old 10-08-2010, 11:33 AM   #12
Nexus1155
Drives: Audi
Yousagonnaneedoneofthesetoo
http://www.theautopartsshop.com/auto...ad-gasket.html
Old 10-08-2010, 02:16 PM   #13
sleey0
For anyone that are having trouble finding the part #'s thank CTScott. I dug up this on ToyoDIY.com
11101A BOLT (FOR CYLINDER HEAD SET)
90910‑02126 1NZFE, 2NZFE..NCP9* (08/2005 - 12/2006) 10 $8.04
90910‑02170 1NZFE, 2NZFE..NCP9* (01/2007 - ) 10
11101B WASHER, PLATE (FOR CYLINDER HEAD SET)
90201‑09024 1NZFE, 2NZFE..NCP9* 10 $1.37
xbgod - 9/23/2010
Old 10-08-2010, 02:25 PM   #14
sleey0
"Should I get a new gasket too? Toyo wants $55.
Is there any better options?
xbgod - 9/23/2010
Old 10-08-2010, 04:00 PM   #15
sleey0
Just ordered the 10 studs with washers!
Now, they quoted me $45 for the gasket.
Is there a better option, or is a gasket a gasket? lol
xbgod - 9/23/2010
Old 10-08-2010, 08:01 PM   #16
Nexus1155
Drives: Audi
So did the AJUSA head bolts hold up? I have a set for a Toyota, 1.8 L , 2001. The head gasket supplied was an eristic. No good reports from me on the eristic head gasket. It is leaking like a sive after only 30 minutes max run time.
I just wanted to clarify, the head bolts from AJUSA seem to just fine.
The Eristic Head Gasket is the suspected failure point. I have heard many others complain about the Eristic Head Gasket too.
I plan on using the AJUSA head bolts and a FELPRO Head Gasket this time.
Thats why i posted the previous link, apparently some have failures
Old 10-08-2010, 08:10 PM   #17
sleey0
Thank you but it doesn't matter now because I got the head studs and washers and gasket from toyota.
xbgod - 9/23/2010
Old 10-09-2010, 02:50 AM   #18
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by sleey0 View Post
Got it.
Change the pistons also. The ringlands are weak.
If you don't want to go through the hassle of building your own block, we offer one now. http://www.ptuning.com/html/Item-Des...l&ModelDesc=xA
Ptuning.com
Blown_xa is offline   Reply With Quote
Amp with Stock Head? Boy Blue In Car Entertainment + Electronics (audio / video / alarm) 11 06-11-2011 11:53 AM
Head Liner / Ink removal bikegerm Cosmetic Modifications (Exterior/Interior) 11 06-23-2009 03:56 PM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
human head in coffee beans wushumasterku Off-topic / Other Cars / Everything else Discussions 8 04-19-2006 11:39 PM
