#19 | |
![]() ![]() ![]() Drives: 00 itr Join Date: May 2006
#20 | |
The LittleBastard
Drives: 2007 Yaris Liftback Join Date: Sep 2006
Yaris Mods: 20% Tints Ground wires 2007 Toyota Yaris Liftback - Current 2004 Honda S2000 - Sold 1986 Toyota Corolla SR5 - Sold DIY: Groundwire Kit |
#21 |
if u want a ride we can meet up somewhere and i wouldnt mind taking you for a spin to show u that once u do suspension work to the yaris ur car is fun to drive
#22 | |
The LittleBastard
#23 |
my suggestions if you want custom spring rates are as follows:
tanabe sells their pro210 springs, these are replacements for coilovers. all that needs to be determined is the diameter of the spring. http://www.tanabe-usa.com/springs/pro210.asp or you can really upgrade with a set of swift springs, you're looking at approximately the same price for both. around $90.00 each. as for valving, you probably have a 1k-2k area to swing the spring rates. |
#24 |
![]() Drives: Hopefully a 07 Yaris HB Join Date: Sep 2006
Can you tell me how's the ride after the coilovers installed? Is it bouncy at all?
#25 |
lets just say i was going to work and i had a cup of orange juice within 5 min i saw half of it spill out that really pissed me off so no more open drinks in the car but it doesnt bother me just go slow over bumps but when ur driving fast it doesnt even bother me
#26 |
From what you said so the coilovers are too stiff or bouncy for you?
#27 |
![]() ![]() ![]() Drives: 2007 Yaris Liftback, 5-speed Join Date: Oct 2006
I'm wondering: what are the major differences between the Cusco Compact-S coilovers and the Cusco Zero-1 coilovers? I see that the Zero-1 series is more expensive... just wondering if it is that much better. Also, does Cusco make a Zero-2 (adjustable dampening) application for the Yaris?
#28 |
the comp-s is their entry level. ride height adjustability is not independant of the spring, so when you change the ride height you are changing the load on the springs. the zero-1 are independant of the spring load when adjusting the height so it stays constant no matter the height. the damper is also a little better and the dampening is a little stiffer. iirc comp-s is a kyb damper and zero-1 is showa.
#29 |
OK, thanks for that info. The Zero-1 looks like a better setup, then. So I take it that there is no Zero-2 model available for the Yaris yet?
#30 | |
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
| Cusco Comp-S Coilovers on their way!!! | BulletProofAuto | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 05-22-2007 01:45 PM |
| Comp S Coilovers for a discount and installed | BulletProofAuto | California | 1 | 05-12-2007 02:04 AM |
| Cusco Type 1 Lower Bar Installed [pics] | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 23 | 10-19-2006 07:57 PM |
| has anyone installed a 3dr liftback lip spoiler? | DonnyRebel | DIY / Maintenance / Service | 10 | 09-14-2006 01:04 AM |
| cusco or c-one? | dngz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 09-12-2006 08:53 PM |
