Old 09-16-2006, 01:51 PM   #1
badhabitz
badhabitz's Avatar
Drives: yaris
Send a message via AIM to badhabitz
cusco coilovers installed
alright guys i just finished the install yesterday
thanks john at bulletproof for hooking it up with the cuscos the total time for the whole install took me about 2 hours.
ok lets start with the rear cause that is the easiest i was able to have access to a lift and power tools so it made things a lot quicker.
these are the tools i used
20mm for the lug nuts
14mm for the rear strut nut
14mm for the inside rear strut nut
so the first thing i did was pop of the plastic cover in the inside of the car then loosen the 14mm thats holding the strut to the car
then i lifted up the car and the springs fell off and the strut came out also
this is wat the stock ones look like compared to the cusco
go ahead and transfer over the plastic shield for the rear strut to the cuscos so they look like this
i wasnt sure wat side the spring goes but i figured the adjusters went below but others say they go on top
transfer over the rubbers from top to bottom on the spring
stick the strut on and hand tighten the 14mm for the strut for now and put the spring onto the subframe use a jack and jack up the subframe
align everything and get the spring to line up and the strut to enter the car with no problem
tighten all the bolts and the rear is done
this is wat is should look like when its done i didnt slam the rear all the way
now to the fronts
push in the plastic clips there are 3 one right one left and one in the middle
next pull the panels out making sure nothing is caught onto it
disconnect the windshield washer fluid from the left and the rest of thepanels should come out looking like this
pop off the wiper covers and take the nuts out using a 14mm wiggle it out and they should come out
then the rest ofthe panels should come out
take the rubber boot off the top
i was lucky to have this tool an angled wrench 17 and a allen to take the front struts out with not too much of a problem because theres not a lot of room to work with and people always cut there hands.
loosen the top nut and now at the bottom take the 2 19mm nuts off holding the strut to the spindle ,take the sway bar link off using a 17mm, and take off the 14mm bolt holding the brake line on.
i used a bungy cored to hold on the to brake rotor from dangaling around but after u take out the strut it looks empty like this
some use a spring compressor to take out the spring because we are going to have to use the top mounts for they are not given. what i did was put the strut on the ground have a friend stand on it and i used my impact to take it out applying pressure and bam it comes right out dont be scared it wasnt too bad.
i didnt reused the bump stopper and the boot cause cusco already provides those.
next i put the strut in and pushed up on the strut and tightend the 17mm on top by hand till i couldnt any more.
then i reinstalled the bolt and nut for the shock and the sway bar link and the brake line.
to make things easier i used a jack to push up on this assembly to line up with the shock
tighten everything and then the top nut comes which took me like 5 minutes to tighten with not a lot of room to work with
i put all the panels back and double checked my work
lowered the car and slammed the fronts all the way
the install is finally complete here are some pics of my car hope you guys enjoyed it
badhabitz is offline   Reply With Quote
Old 09-16-2006, 02:59 PM   #2
dngz
dngz's Avatar
Drives: black yaris sedan
niiice!!! but... i think ur vitz is on the wrong side ><!!
dngz is offline   Reply With Quote
Old 09-16-2006, 03:38 PM   #3
C2AUTOSPL
Drives: 240sx, 00 Celica
so it fits nicely then...
SUPPORT YARISWORLD'S VERY FIRST SPONSOR!!
C2 AUTOMOTIVE SPECIAL
24711 Redlands Blvd., Ste. I
Loma Linda, CA 92354
T: 909-796-8189
E-mail: info@c2auto.com
AIM: wide180sx
C2AUTOSPL is offline   Reply With Quote
Old 09-16-2006, 04:29 PM   #4
SmellyTofu
好多人&amp;
Drives: .
Interesting you didn't take out the whole wiper assembly to get access to the top hat nut. I didn't use a wrench to get at the top nut though.. I'll remember that when I take the gear off the car.
Old 09-16-2006, 06:06 PM   #5
riceboy
Drives: icebox
Looks good...
riceboy is offline   Reply With Quote
Old 09-16-2006, 08:41 PM   #6
Boo
Boo's Avatar
Drives: PW Yaris LB AT
It is stunning!!!
Boo is offline   Reply With Quote
Old 09-17-2006, 07:28 AM   #7
RossP
Drives: MK I Vitz 1.0l F Package
Steel wheels must die!!
Looks good otherwise dude
RossP is offline   Reply With Quote
Old 09-17-2006, 03:09 PM   #8
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Ηave you tested it on the road?
Old 09-17-2006, 06:59 PM   #9
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Love the look... Im sure your car must track awesome with all the suspension mods you have done.. has it been to the track yet?
Old 09-17-2006, 09:05 PM   #10
badhabitz
badhabitz's Avatar
Drives: yaris
no it hasnt been to the track yet but i will soon the car drives great i can take turns in 3rd gear going about 40mph but what i noticed is what i really need is an lsd ill wait till i need a clutch and do short gears and a lsd
Old 09-17-2006, 10:26 PM   #11
SmellyTofu
好多人&amp;
Drives: .
Stick with the 15" ... they do make the car much faster off the line with less weight to turn than 16". Anyway, the tyres will be cheap in 15" so keep burning them. :) I do.. sometimes.
Old 09-18-2006, 01:21 AM   #12
BulletProofAuto
Drives: 00 itr
great writeup Ken, they look great on your car...glad i could help supply these to you. car looks very nice, we'll get some wheels on soon ;)
BulletProofAuto is offline   Reply With Quote
Old 09-18-2006, 10:10 AM   #13
03Z33
03Z33's Avatar
Drives: TCR10
Very nice! I'm jealous
You may want to pick up the max negative camber bolts from Toyota before taking it in for alignment... The 12.4mm ones are the smallest and should get you at least -1.2 deg. if not more
03Z33 is offline   Reply With Quote
Old 09-18-2006, 12:56 PM   #14
mrlam
mrlam's Avatar
I am very jealous too
mrlam is offline   Reply With Quote
Old 09-18-2006, 01:38 PM   #15
BulletProofAuto
Drives: 00 itr
just some information for everyone on what i feel are the most important specs to compare when suspension shopping. if you don't like to read, see the cliff notes at the end.
cusco compact s spring rates
F:7k
R:3.3k
Non adjustable dampening
~$1200
HKS S-Compact
Spring Rates
F:5k
R:8k
30 way adjustable dampening
~$1900
Tein Basic
F:4k
R:3.1k
Non adjustable dampening.
~$950.00
As you can see the spring rates are very soft for the basics, cusco and hks are much more aggresive with their rates and the valving to go with it. In terms of comparing what is the best setup to get, I believe the Tein does not offer anything outside of height adjustability since the spring rates are no stiffer then what is found from Tanabe's springs, of which there will be a GF210 coming out with ~4k rates(it's out in Japan, it'll be out here). The cusco is your best performance related upgrade since the Tein would be purely cosmetic. For those that want something more trackable, the HKS would be your solution with the ability to fine tune your dampening for different course and driving situations. Of course at this time the HKS are not readily available in the states, I don't see HKS USA bringing this product over anytime soon as stockable inventory so you'll need to wait for it. The cusco and tein products will be stocked stateside, it just may take some time for the suppliers to gauge the correct inventory levels so expect backordered product in the beginning.
Cliff Notes:
Cusco compact S is probably best value at the moment.
HKS is tops for track use.
Tein Basic is purely cosmetic.
Old 09-25-2006, 02:52 PM   #16
BulletProofAuto
Drives: 00 itr
1 set will be arriving end of october, if you'd like it i recommend ordering it now.
http://www.bulletproofautomotive.com...il.php?ID=5268
Old 09-25-2006, 03:16 PM   #17
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
Wow Looks great. Sure it rides nice also, but must be stiff ride.
John I would have thought teins would be adjustable also, surprised to see they aren't. So it's a basic coilover with no shock adjustments, and low spring rates? I'm not looking to upograde my yaris in performence, so maybe just a cosmetic upgrade would be better for me.
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 09-25-2006, 07:42 PM   #18
BulletProofAuto
Drives: 00 itr
the only adjustable ones that i've seen are the hks. the cusco comp-s, zero-1, and tein basic are all non adjustable dampening.
the cusco has rather stiff rates compared to tein, i remember making a post somewhere around here regarding spring rates, i'll need to find it.
Cusco Comp-S Coilovers on their way!!! BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 05-22-2007 12:45 PM
Comp S Coilovers for a discount and installed BulletProofAuto California 1 05-12-2007 01:04 AM
Cusco Type 1 Lower Bar Installed [pics] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 10-19-2006 06:57 PM
has anyone installed a 3dr liftback lip spoiler? DonnyRebel DIY / Maintenance / Service 10 09-14-2006 12:04 AM
cusco or c-one? dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 09-12-2006 07:53 PM
