Old 11-18-2010, 12:22 PM   #1
Moratiya
Drives: 2007 Toyota Yaris, red
How to turn on the running lights and fog lights @ same timewhile/headlights off ...?
I've always liked how some brands have the option to turn on the running lights and fog lights at the same time while the headlights are turned off. Is there a way to change this on the yaris? the fog lights turn on only when the headlights (and fog lights switch is on) are on. Thanks
Moratiya is offline   Reply With Quote
Old 11-23-2010, 02:28 PM   #2
Judas Iscariot
Drives: 2008 Yaris HB
Have also been searching and i cant find anything!
Bump.
Judas Iscariot is offline   Reply With Quote
Old 11-23-2010, 03:04 PM   #3
If your fogs are OEM or are wired via the OEM relay this will allow you to be able to turn them on at will:
Take the wire that is in pin 4 of the headlight stalk (it will be orange, beige or white, depending on year and if you have DRLs) and cut it (leave yourself some room on either side of the cut to be able to work with the wire.
Take the harness side of the cut wire and cap it off.
Take the connector side of the wire and tap it to the white wire in pin 7 (the smaller white wire with the black stripe).
Old 11-27-2010, 09:07 PM   #4
PenquinZ111
Drives: RC yRs LB
i remember this from 3 years ago. well i just unplugged the DLR relay. Doing that will just turn on the little 194 wedge bulbs and not the headlight, when turning the headlamp switch one tick. its located under the dash, just right of the steering column, if i can remember.
PenquinZ111 is offline   Reply With Quote
Old 11-27-2010, 09:08 PM   #5
PenquinZ111
Drives: RC yRs LB
wow your good scott!!!
Old 12-07-2010, 11:13 PM   #6
Rnankoo
Rnankoo's Avatar
Drives: Toyota Yaris meteorite silver
turn the car off pull the ebrake up on notch then turn the car on leaving the ebrake up one notch the parkin light will be off
Rnankoo is offline   Reply With Quote
Old 12-10-2010, 11:10 PM   #7
Almost. Connect your red "jumper" to the other side of the cut that you made in the orange wire.
Old 12-11-2010, 05:35 PM   #8
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
got it on the second try now i can breath ahhh
i should not drink and splice
OTA'sTOY is offline   Reply With Quote
Old 12-11-2010, 06:40 PM   #9
That just means that you hadn't had enough on the first try.
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 05:21 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
