Old 11-22-2010, 05:47 PM   #1
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
How do you roll fenders in?
I need help with this people that have done it or people that knows how, how did you do it? Any technical way or special way to do it ? Who would do this? Tires shop? Body work shop? I been wanting to do this to my sedan and the LB
Originally Posted by sw07gt
Old 11-22-2010, 05:51 PM   #2
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Is this YouTube video what you are talking about? (It made me laugh)
Heres another one.
(Edit: PS> There are better vids on youtube, these just made me laugh)
Old 11-22-2010, 06:02 PM   #3
What I did for my rear was this:
Heated a section fender lip with a heat gun, then I wedged an aluminum pipe between the tire and the fender. I gently started rolling the lip. Heat the next section, gently roll. Repeat until then whole fender lip is slightly rolled. Then just repeat the process, putting more pressure down the pipe to roll the fenders more. You'll destroy the weather stripping on the fender lip in the process, but eh, don't see the point in those anyway. It's really important to heat the fender lip tho as to not crack the paint. It'll take a while if you don't want any damage (took me around three hours I think, to do both sides). You don't want to really roll an area of the fender right away. You'd want to gradually roll the entire fender, as I mentioned.
Old 11-22-2010, 06:07 PM   #4
I did mine at the track with a baseball bat, but it did chip the paint. There is a special tool with urethane wheels that the pros use.
Old 11-22-2010, 06:16 PM   #5
Yaristeve
Drives: 3-door hatch
Depending on how much clearance you need, an alternate technique I've read about is shaving the lip. If you only need a few millimeters of clearance, you can cut away the inner lip up to the spot welds. No damage tothe paint and you don't risk breaking or weakening the spot welds. More info at the My.IS (IS300) forums...
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
Ignition vs. Roll start? Alypuppy Fuel Economy Forum 53 05-18-2010 10:51 PM
Roll center adjuster d1nzfe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 05-16-2010 04:59 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Rolling Fenders slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-28-2006 04:45 PM
