Old 05-09-2010, 09:30 AM   #1
d1nzfe
Drives: 1NZ-FE
Roll center adjuster
Anyone on these? They are very pricey though.
Supposed to lower the roll center after u lowered your car. Reduce roll during cornering.
d1nzfe is offline   Reply With Quote
Old 05-09-2010, 09:39 AM   #2
Perhaps you could put a link up to what they are and what they do. I've never heard of them.
Old 05-09-2010, 09:45 AM   #3
d1nzfe
Drives: 1NZ-FE
Old 05-09-2010, 09:57 AM   #4
At stock ride hight the arm is pointing slightly downward, not straight out. So unless you're more than 2" lowered, you shouldn't need something like that.
Old 05-09-2010, 10:13 AM   #5
d1nzfe
Drives: 1NZ-FE
definitely more than 2". Any trackies comments?
Old 05-09-2010, 10:31 AM   #6
djct_watt
Drives: 2010 NCP91 5spd
Based on the picture, wouldn't that piece just raise right back up to stock height?
djct_watt is offline   Reply With Quote
Old 05-09-2010, 01:31 PM   #7
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
They are not needed the Yaris has a feature likes this built in. Here is a whole thread on it: http://www.yarisworld.com/forums/showthread.php?t=23911 also here too http://www.microimageonline.com/foru...Suspension-Mod!!!!
Old 05-10-2010, 06:24 AM   #8
d1nzfe
Drives: 1NZ-FE
I got it, BUT I am now talking about the front.
Old 05-10-2010, 06:29 AM   #9
djct_watt
Yes, and the built in feature moves the appropriate pivot point. This mod only adds more length to the strut, which defeats the (cosmetic) point of lowering a car. This would be great if all you wanted was to stiffen the suspension, without lowering the ride height. . . which is actually something I am interested in (ground clearance is an issue here in Thailand), but I'd probably rather go with coilovers instead.
Old 05-10-2010, 06:20 PM   #10
markitect
I think the main purpose of these is probably to correct alignment. I think some adjustable camber bolts, and you will be fine
markitect is offline   Reply With Quote
Old 05-10-2010, 08:08 PM   #11
The purpose is to adjust the angle of the lower FRONT control arm.
At stock ride hight, the arm is angled down slightly. When the suspension compresses in a corner the arm pushes out the bottom of the tire creating negative camber. If the arm is already straight out, it can only create positive camber as the suspension compresses.
The diagrams in the 3rd post illustrates what happens pretty well. Remember that the strut will only allow up and down movement, but the control arm moves in a circular sweep.
Old 05-11-2010, 02:15 AM   #12
djct_watt
^ and to properly adjust the geometry, you would need to move the pivot point on the control arm, not adjust the length of the strut (which is what the blue piece does).
On a geometry standpoint, the picture is all wrong. . . but it's probably because a 3rd grader drew it on MS-Paint. There's really no point in me arguing about it. It's impossible to say what the heck it even does without a proper picture.
Old 05-11-2010, 06:27 AM   #13
d1nzfe
Drives: 1NZ-FE
now, we need somebody who actually know the picture here.
Old 05-11-2010, 08:36 AM   #14
Roll center adjuster for honda
Old 05-11-2010, 08:46 AM   #15
djct_watt
No need to be rude. Thanks for the pic. Is that the same exact piece?
Old 05-11-2010, 09:01 AM   #16
kngrsll
Apexing Egg!!
kngrsll's Avatar
they even make them for the vitz! http://www.nengun.com/moonface/front...r-adjuster-pro
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 05-11-2010, 09:03 AM   #17
Same idea. If you could get the stock ball joint out and replace it with a longer one, you regain the slight downward angle of the control arm. You technically should have one for the tie rod too to prevent bump-steer.
Old 05-12-2010, 06:25 AM   #18
d1nzfe
Drives: 1NZ-FE
its is available for vitz thats y i asked..
Rear suspension Maitre_Te_Te Wheels, Tires and Suspension Forum sponsored by The Tire Rack 257 03-30-2021 10:05 AM
center caps for 15" steelies? Lewis Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 07-02-2018 02:50 PM
Ignition vs. Roll start? Alypuppy Fuel Economy Forum 53 05-18-2010 10:51 PM
TOYOTA center caps and Trim Rings for sale. coffiend Items for Sale by private party 10 05-11-2010 06:29 PM
My $7 Interior Upgrade - Center Heater Vents Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 54 05-18-2009 08:51 AM
