Old 12-11-2010, 10:11 PM   #91
Originally Posted by hatch2008 View Post
ill try to upload the diagram tomorrow as it is midnight hear rite now , and yes i have learned the key, it wouldnt work at alll until the key was learned. almost seems like its missing a signal form the ign or immizer.
What's the model number of the one you bought? It looks like their install manuals are available on their website.
Old 12-11-2010, 10:34 PM   #92
hatch2008
Drives: 2008 yaris
this is the by pass im useing and im using type 1 wire diagram.
hatch2008 is offline   Reply With Quote
Old 12-11-2010, 11:02 PM   #93
OK - I assume your remote starter uses the DBI port?
Does the LED stay solid green when starting?
Old 12-11-2010, 11:48 PM   #94
Yaris PAVEL94
Does anybody know how the new apps for Viper remote starters work and how to set it up? Because I'm getting my new phone( BB Curve2)next week and I want to try it.THANKS
Yaris PAVEL94 is offline   Reply With Quote
Old 12-12-2010, 07:36 AM   #95
The ones with the cell phone interface install just like the keyfob ones. The only issue with them is that there is a monthly subscription fee for hanging it on the cell network.
Old 12-12-2010, 09:47 AM   #96
hatch2008
Drives: 2008 yaris
ya mine is using the dbi port
Old 12-12-2010, 10:01 AM   #97
hatch2008
Drives: 2008 yaris
the led is doing the proper lighting when flashing , i spent like 7 hours on this yesterday and made sure all that ws good .
Old 12-12-2010, 10:01 AM   #98
OK - So that meant that you only had to wire it to the key transponder receiver.
Did the registration process go correctly (and is the module showing the green light)?
For your remote starter, what model is that?
If the remote starter didn't have a connection for key presence, the issue may be that the remote starter is telling the bypass module to send the key data at the wrong time.
Old 12-12-2010, 10:06 AM   #99
hatch2008
Drives: 2008 yaris
its a prostart ct 3371 , and as far as i can tell there isnt a key sense connections jus the ign green, the white wire off the ign, the black starter wire. and the imm. hooks into the imm. connctor and obd connector .
Old 12-12-2010, 10:24 AM   #100
hatch2008
Drives: 2008 yaris
im reading through the prostart again and notice inthe programming of the prostart im mode 3 the default is xpresskit, but my bypass is connected to the ads port , so i will try changing that becuase if that is inncorect then the prostart is looking in the wrong place for the by pass, so i could very well be an idiot today lol .. make sense too you
Old 12-12-2010, 02:18 PM   #101
hatch2008
Drives: 2008 yaris
whats the differnece of the ign 1 wire and ign 2 wire on your diy
Old 12-12-2010, 02:52 PM   #102
hatch2008
Drives: 2008 yaris
from what google has told me i need to have ign 1 and 2 connected to a relay which as far as i can tell my prostart instructions say is optinal, also when the car is cranking if i put the key in and to the on pos. it starts. anyone noe what i should do hear , or how the2 ign wires are suppose to be connected. starting to really hate prostart lol.
Old 12-12-2010, 04:06 PM   #103
If you put the key in, but don't turn it, what happens?
Old 12-12-2010, 04:17 PM   #104
The IG2 should be connected to the "5th relay output" and the jumper needs to be in the 2nd ignition output position.
Old 12-13-2010, 01:50 PM   #105
hatch2008
Drives: 2008 yaris
ok so i did have everything connected correctly as i check it over 100 times lol , and i have found and fixed my problem, after finding all my wires connected properly and speaking to scott too assure i had them connected propery, thanks a milllion scott really appricate it, i decided to open up the prostart control unit and make sure nothing seemed out of place , what i found was that two of my pins for my bypass in the prostart unit where not even soldered to the circuit board. i exchanged the unit at my local store, plugged in the new one, programmed it and the remote start worked like a charm. jus thought i would post this incase some else has a similar problem, sometimes you may be doing it right but the brand new part is faulty. thanks again scott
Old 12-13-2010, 02:00 PM   #106
Wow! That was a good (bad) find. It is amazing how poor quality control is on so many products these days.
Old 12-13-2010, 05:08 PM   #107
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Wow, was this thing made in the USA or something? :D
(I keeeed)
Old 01-23-2011, 03:20 PM   #108
samltd
Drives: yaris
Help installing Avital 4003/Fortin Key Override All
Hi,
I'm trying to install an Avital 4003 remote starter add-on module with a Fortin Key Override All transponder key bypass.
I need help to figure out how to connect the remote starter/transponder bypass to the wires shown by CTScott in his manual.
So far I identified Avital and Fortin Installation instructions to match CTScott's manual
Avital 4003
Primary harness (H1), 9-pin connector
H1/1 LIGHT GREEN/BLACK (-) FACTORY ALARM DISARM -
H1/2 GREEN/WHITE (-) FACTORY ALARM REARM -
H1/3 YELLOW (+) IGNITION OUT (TO ALARM) -
H1/4 WHITE/BLUE (+/-) ACTIVATION INPUT -
H1/5 ORANGE (-) GROUND WHEN LOCKED - Available only when adding a receiver (P/N 543H) and remote (P/N 474L)
H1/6 BROWN (-) HORN OUTPUT - Available only when adding a receiver (P/N 543H) and remote (P/N 474L) - Horn in DIY manual
H1/7 RED/WHITE (-) TRUNK RELEASE OUTPUT - Available only when adding a receiver (P/N 543H) and remote (P/N 474L)
H1/8 Black (-) CHASSIS GROUND CONNECTION - Ground in DIY manual
H1/9 White (+/-) LIGHT FLASH OUTPUT - (+) Factory configured - (+) Parking lights wire in DIY manual
4-pin satellite harness diagram
1 BLUE (-) STATUS OUTPUT - ?
2 ORANGE (-) ACCESSORY OUTPUT - ?
3 PURPLE (-) STARTER OUTPUT - ?
4 PINK (-) IGNITION OUTPUT - ?
Heavy gauge
1 PINK (+) OUTPUT TO IGNITION CIRCUIT - Ignition #1 GREEN in DIY manual or #1 PINK as per post #35 Skylinecar1982
2 PURPLE (+) OUTPUT TO STARTER CIRCUIT - Starter in DIY manual
3 ORANGE (+) OUTPUT TO ACCESSORY CIRCUIT - Accessory in DIY manual
4 & 6 RED (+) (30A) HIGH CURRENT 12V INPUT - They must be connected to a high current source. Since the factory supplies (+) 12V to the key switch that is used to operate the motor, it is recommended that these wires be connected there - (+) Battery Voltage in DIY manual ?
5 PINK/WHITE (+) PROGRAMMABLE OUTPUT FOR ACCESSORY OR IGNITION - Ignition #2 PINK in DIY manual or #2 GREEN as per post #35
Remote start harness (H2), 5-pin connector
H2/1 BLACK/WHITE (-) NEUTRAL SAFETY SWITCH INPUT - ?
H2/2 VIOLET/WHITE TACHOMETER INPUT WIRE - Tach signal in DIY manual
H2/3 BROWN (+) BRAKE SWITCH SHUTDOWN WIRE - Brake switch in DIY manual
H2/4 GRAY (-) HOOD PINSWITCH SHUTDOWN WIRE - Hood Safety Switch in DIY manual
H2/5 BLUE/WHITE (-) 200mA 2ND STATUS/REAR DEFOGGER OUTPUT - ?
Purple/White RX Data In - RX in DIY manual
Yellow/Black RT Data Out - RT in DIY manual
Blue (-) While running - Remote starter in DIY manual ? Where to the remote starter?
Green Key Sense - Key Sense in DIY manual
Red +12V - (+) Battery Voltage
Black Ground - Ground
Thanks
samltd is offline   Reply With Quote
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
