Old 02-08-2011, 05:19 PM   #379
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Is anyone welding there own exhaust pipes. I'm looking into buying a welder and I'm having trouble deciding what type of welder to go with. MIG, TIG or a cheap flux core wire welder that doesn't use any gas. I want to be able to weld stainless and aluminized exhaust pipes. I am very limited by the fact I can only use 120 volt set up in my town house.
pimp my yaris is offline   Reply With Quote
Old 02-08-2011, 05:22 PM   #380
I'm shopping too. I've been told that for aluminum I have to get a TIG.
Old 02-08-2011, 05:35 PM   #381
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
For Aluminum, you need an AC welder for TIG and I'm pretty sure for MIG as well. TIG is not for beginners, so if you've never really welded before go with a MIG. You can buy the adapters for welding Aluminum, but again, I'm pretty sure it needs to be capable of doing AC. Most steel is welded with DC, and most cheaper welders are DC only.
Old 02-08-2011, 05:45 PM   #382
pimp my yaris
C'est la vie
I think I will go with a mig welder. My stainless exhaust was welded with a mig and its not pretty but its solid with no cracks. Although I hear Tig is the best for stainless, its sounds like more trouble and expense. The guy who welded my exhaust said you can weld stainless with a mig welder, but U need to be fast or it will burn through the pipe.
Old 02-08-2011, 11:56 PM   #383
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
this will work for you.
http://www.millerwelds.com/products/...p?model=M00152
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 02-09-2011, 12:25 AM   #384
^ Yeah. I want it.
Old 02-09-2011, 05:41 PM   #385
pimp my yaris
C'est la vie
One more. A lot cheaper. Rand 100amp stick/TIG http://cgi.ebay.com/Rand-TIG-Stick-W...item3f0717083a
File Type: jpg !CEyF5BQCWk~$(KGrHqUOKjEE0lRmC9ZYBNT!g7YZIQ~~_12.jpg (23.2 KB, 289 views)
Old 02-10-2011, 09:34 AM   #386
Bluevitz-rs
yeah, but neither of those will do aluminum. They need to output high frequency AC.
Old 02-10-2011, 10:21 PM   #387
scioncrew
scioncrew's Avatar
Drives: SCION tC
he didnt say he was going to weld aluminum. any ways check this one out
http://www.millerwelds.com/products/...ty_200_series/
Old 02-11-2011, 01:19 AM   #388
^ $6k? ouch!
Can't I get a good 220v TIG for around $3k that will weld aluminum?
Old 02-11-2011, 02:52 PM   #389
Bluevitz-rs
...I want to be able to weld stainless and aluminized exhaust pipes...
I miss red this as aluminum pipe.
Old 03-01-2011, 04:40 PM   #390
pimp my yaris
C'est la vie
Headed to Florida for Daytona bike week. Wish I had my turbo back on. I hate downshifting in the mountains when pulling my trailer. I had the crack in my manafold welded and now I'm waiting for my friend to mill about .0020" off the engine side as it is badly warped. I guess I got it a little bit hot.
Old 03-29-2011, 04:29 PM   #391
pimp my yaris
C'est la vie
Started working on the car again today. Mounted new manafold, new turbo and managed to get my old downpipe to fit with some clearance. Should be driving by thur. or fri. I drilled out my banjo bolt on my oil feed line so it will no longer act as a oil restrictor. Hopefully this will keep my turbo bearings spinning for longer then four months.
Old 03-29-2011, 07:33 PM   #392
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
What turbo did you get?
Old 04-01-2011, 10:29 AM   #393
pimp my yaris
C'est la vie
Unfortunatly I could not come up with the cash for the Garrett gt 2554r. So for now I bought the same old cheap turbo I had before. I reused my modified compressor housing on the new turbo. I also ground down the divider wall between the wastegate and turbine wheel. It is givin me very consistant 7psi with no boost creep. The car is runing great and I even blew the discharge tube off the turbo once. Just a loose clamp. So glad my car has balls again. You can see in the pics where the old compressor wheel started to contact the housing when the bearings wore out.
Old 04-01-2011, 02:25 PM   #394
welcome back
Old 04-17-2011, 02:02 PM   #395
pimp my yaris
C'est la vie
I know its only been a couple of weeks but I pulled off my intake hose and checked the turbo bearings for wear. They are looking good. No noticable play at all. I think my problems with the previous turbo were caused by that oil restrictor. I guess I will check again in a month or so. I also made a bracket from a piece of L-shaped steel stock to support the added weight of the turbo manafold and turbo. Hopefully this will help prevent the manafold from cracking again.
Old 04-17-2011, 03:06 PM   #396
Yoda
Yoda's Avatar
nice welcome back. I have been running a restrictor on mine for about 3 months and no play at all on my turbo. But i did find out where that smoke was coming from. Need to replace the exhaust gasket. Is your wastegate set at 7 psi or are you using the same old spring trick?
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
