Old 08-14-2007, 10:28 AM   #1
cdydjded
Drives: Yaris LB Turbo
Under $2500 Turbo Kit w/Intercooler coming soon!
OK you guys have asked for it & you will get it. I have almost finished a turbo kit for under $2500. It will feature the following:
Custom manifold
T25/T28 turbo with internal wastegate
Front mount intercooler
All piping, t bolt clamps, hardware, gaskets ect
For engine managment I will be using one of the following:
Camcom
Blitz RVIT-i
Apex SAFC
AEM FIC
I will sell the kit with or without the engine managment. I will be also trying each item & recomend the best one for the turbo kit. Now I read alot of people saying that when this alternative would come out they would jump on it like white on rice. Let's see who is on board.
cdydjded is offline   Reply With Quote
Old 08-14-2007, 10:45 AM   #2
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
Cool, now I just need a supplemental income...even a winning lotto ticket would suffice
YarisTom73 is offline   Reply With Quote
Old 08-14-2007, 10:59 AM   #3
First of all, thank you for your work on this, I'm glad some options are coming out for our cars.
I don't don't like internal wastegates in general, but... If you (1) show all kit parts clearly in pictures and an installed kit and (2) post dynos (preferably NOT on a Dynojet)
then I'd be interested.
1. what wastegate are you using? (this is especially important with an internal wastegate)
1a. What spring will the wastegate come with?
2. what blowoff valve are you using?
3. Will the management come with a p 'n p harness?
4. is this going to use stock injectors?
I can think of more questions, but lets' start with these.
Old 08-14-2007, 11:21 AM   #4
cdydjded
I have before about your dislike of internal wastegates & would like to know what is you problem with it? Here in Miami we only have Dynojets. Again what is the problem? As for your questions:
1) the tubo is made by Mitsubishi so it is made by them
1A) low boost 5lbs
3) No most will have to be hard wired (price is the issue) the Blitz plugs in to the port under the dash
4)depends on the results with them
Old 08-14-2007, 11:38 AM   #5
redduck
I had a feeling you where cooking up something after reading your recent posts and replys.
redduck is offline   Reply With Quote
Old 08-14-2007, 11:47 AM   #6
thanks for the answers. If you can reply to question 2. that would be good also.
As for wastegates, an internal one is fine as long as you never want to change anything, and it never fails. I like the flexibility, as I have never seen an aftermarket bolt-on turbo kit that didn't need quite a bit of tweaking for power and reliability.
Hard wiring a management unit will add considerably to the cost. I am cool with that, but anyone considering this set up needs a really good tuning shop near them to wire it up and tune the car. I would interview the shop and get a quote before purchasing the kit.
I hope the stock injectors work out, that would help keep the cost down -- the last set of four I bought cost about $350, does that sound about right for our car?
Here's a question -- what are our stock injectors rated at in cc's?
Old 08-14-2007, 12:53 PM   #7
cdydjded
Sorry for not replying to #2:
2) not sure yet, something inexpensive to keep the kit cost down
As for the internal waste gate you do realize that some of them do come adjustable right? On the engine managment I am shooting for the Blitz unit to work since it is a plug n play unit.
Old 08-14-2007, 01:33 PM   #8
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
First Off... Thank you for doing this... I definitely Under-estimated you... and I'm sorry!
2nd: Who made the Custom Manifold?
3rd: Will there be a CAI available?
4th: Will you make a Stage 0 Kit, Without the Intercooler and all that piping?
5th: How much wood could a woodchuck Chuck, if a Woodchuck, could chuck wood?
*Philosophy of life... Brought to you by... "Nutzoids"
Nutzoids... Where Punk rock is less about Image, and more about the Mind!
Nutzoids is offline   Reply With Quote
Old 08-14-2007, 01:49 PM   #9
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Smile +1
+1 ... I'm interested, but I'd like to see more details of the kit... keep up the good work!
fu_im_from_texas is offline   Reply With Quote
Old 08-14-2007, 02:26 PM   #10
cdydjded
Manifold was made by TD Autowerkes http://www.tdautowerkes.com/
CAI not nessesary for turbo kit
Yes I will offer it without an I/C
A wood chuck could chuck as much wood as a wood chuck could chuck if a wood chuck could chuck wood
Old 08-14-2007, 04:19 PM   #11
nebulight
Novice Hypermiler
Drives: 2007 Toyota Yaris
Send a message via AIM to nebulight
It's a slow start, but I'm shooting for 45mpg by summer. Best so far is 42.23mpg
nebulight is offline   Reply With Quote
Old 08-14-2007, 07:08 PM   #12
joey1320
joey1320's Avatar
Drives: Yaris LB
how will you be able to deal with the adaptaion values being reset by the ecu?
Old 08-14-2007, 08:01 PM   #13
johnnyfive
johnnyfive's Avatar
thank you, that was the one question i was looking to get answered :) :P
and i would imagin at this point you would still need to keep the O2 sensor unpluged as the late ZPI had done...and until something big happens i would imagine we would have to keep the check engine light...
Old 08-15-2007, 01:32 AM   #14
Jerkratt
Jerkratt's Avatar
we can keep using a scan gauge or something and keep clearing the code..... lol
"It hurts more when its wet"
Old 08-15-2007, 10:56 AM   #15
joey1320
joey1320's Avatar
Drives: Yaris LB
the code will always be there since you have remove it. so if you can deal with it ok.
Old 08-15-2007, 11:06 AM   #16
Black Yaris
der Zeck
Black Yaris's Avatar
we just need a CEL fix... anyone interested in getting ahold of the JDM turbo ECU? I do not know much about turbo's but would that solve some problems with the CEL?
Old 08-15-2007, 02:31 PM   #17
cdydjded
About the CEL, I would like to know with the 2 guys that have the ZPI kit why they removed the O2 sensor? Also if they tried to use a O2 simulator.
Old 08-15-2007, 03:50 PM   #18
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
Is your car up and running? Sorry if I dont pay attention :P
Also, if it is, how long? Interested to see what you tune with and if the ECU learns around it.....
Turbo&Auto is offline   Reply With Quote
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
Garrett Turbo kit elsteverino889 Forced Induction Forum 24 04-20-2007 10:27 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
Turbo Kit Teaser Pics cdydjded Performance Modifications 27 01-31-2007 12:58 AM
