Old 02-16-2011, 12:02 AM   #1
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Causes of fast front tire wear?
Ok I been having fast wear out on the front 2 tires and o think its because of the camber bolts the car has, las year during the Import Alliance meet on the last day my front 2 tires decided to go out thanks to Mike I was able to make it back home since he had 2 extra steelies in his car, isn't that crazy?
I put on a different set of wheels with fairly new tires and I decided to look at the back ones just to check and DAMN they are wearing out fast. I have just got a new set but before I mount them I need some one to tell me WHY is this happening. Alignment? Camber bolts? Coilover? WTF LOL
Thanks for a reply
PS: Mike you will be seeing these again this summer. Lol
Originally Posted by sw07gt
Old 02-16-2011, 12:49 AM   #2
bkndacn
bkndacn's Avatar
Drives: 2009 Toyota Yaris
Well Idk what your driving habits are but both me and my friend (MT and AT respectively) spin our front tires constantly ( maybe bc we drive like maniacs?! lol ) Im actually replacing my tires tomorrow (YAY!) because they are bald as hell but the front are worn more than the back... although i have gotten them to almost the same wear by sliding my ass end out alot lol (its fun!)
I got a ride in Garms' Yaris and got on a plane within 24 hours of each other.... his yaris was faster! I bet if he put wings on it he could get passed all that L.A. traffic!
bkndacn is offline   Reply With Quote
Old 02-16-2011, 09:42 AM   #3
sex
sex's Avatar
Drives: 09 5DR
what's the pressure and is the wear even? what tires do you have?
sex is offline   Reply With Quote
Old 02-16-2011, 09:50 AM   #4
+1000, more information.
Where is the wear? and where are the pics?
Old 02-16-2011, 10:23 AM   #5
JumpmanYaris
USAF_SrA_E-4
I could take pictures but I don't think it would help the wear looks evenly. Tire pressure unknown and my driving habits are as usual (normal) from work to home and home to work no spinning tires since my car is AT and has heavy wheels
Old 02-16-2011, 10:52 AM   #6
sex
sex's Avatar
Drives: 09 5DR
even wear suggests your pressure is ok. best to verify with a gauge.
still interested in make/model of tire and the treadwear rating.. maybe you can warranty the tires for the fast wear?
Old 02-16-2011, 11:33 AM   #7
JumpmanYaris
USAF_SrA_E-4
But this is the second set that this has happened so that tells me its not the tires 2 different brands of tires as well, I ll take a picture of the old ones
Old 02-16-2011, 12:07 PM   #8
Tire pressure and oil level are the two most important things to check regularly.
What is your tire rotation schedule?
Old 02-16-2011, 12:16 PM   #9
JumpmanYaris
USAF_SrA_E-4
Every time i get a oil change at the dealershit
Old 02-16-2011, 12:16 PM   #10
sex
sex's Avatar
Drives: 09 5DR
you have fast wear in the front only for set #1 and fast wear in the back for set #2?
there's a tire wear pattern at http://www.2carpros.com/articles/how-car-tires-work .. which does yours look like?
Old 02-16-2011, 12:17 PM   #11
JumpmanYaris
USAF_SrA_E-4
No bud its all front
Old 02-16-2011, 12:27 PM   #12
JumpmanYaris
USAF_SrA_E-4
thats a useful site man well i think its alignment problems then, lloked the the picture in the site and walked out to look at my tires the car has now and looks like that might be it. pics in a few ....
Old 02-16-2011, 12:34 PM   #13
JumpmanYaris
USAF_SrA_E-4
The small pics are back tires the big one is front, so i take that back they aren't wearing evenly
Old 02-16-2011, 12:59 PM   #14
Jason@SportsCar
Camber alone won't typically kill a tire - my RX-8 has nearly -2 degrees all around and I get 30k+ miles out of my tires - I would guess your have excessive toe (in or out) in the front.
Old 02-16-2011, 01:00 PM   #15
sex
sex's Avatar
Drives: 09 5DR
i blame the camber bolts
Old 02-16-2011, 01:02 PM   #16
JumpmanYaris
USAF_SrA_E-4
its 2 degrees just like u
Old 02-16-2011, 02:36 PM   #17
big lo
big lo's Avatar
Drives: 2007 VIOS
Orlando have you tried getting the front aligned? Before any thing just to make sure
Old 02-19-2011, 03:59 PM   #18
LBjoe
LBjoe's Avatar
Drives: Red LB
I'd say its camber in/toed out.. Does the inner tread feel feathered that'd be the toe.. and inner edge wear is part of being lowered and camber going negative.. Also being Toyota mechanic one thing i have noticed that these cars scrub quite hard especially yaris, prius, camry and Tc's at lower speeds.. (the tire stays flat on the ground versus rotating or tilting with the turn). I'd like to see how your alignment is.. also Rotations are key with Toyota.. honestly every oil change i do it.. I know it sucks but We're talking extending tire life by 5-10 k if done religiously.. Also there's not much you will do on rear tire wear as these are a solid rear axle.. shimming is about it but good luck finding someone who really wants to deal with it since you've lowered ur car. Hope this helps at all.
TRD
LBjoe is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Question about bi amping front components. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 08-28-2010 12:04 PM
Tyre wear and tear shb General Yaris / Vitz Discussion 7 06-21-2010 12:57 PM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
