Old 04-03-2011, 06:59 AM   #1
*MAD DOG*
*MAD DOG*'s Avatar
Can you put 195 60 15 tires on 185 60 15 rims?
Hey peeps,
Just wondering, is it safe to put 195 60 15 tires on 185 60 15 rims. I need some new rubber and for some reason 195 is cheaper than 185.
Thanks
*MAD DOG* is offline
Old 04-03-2011, 08:02 AM   #2
When you look at tires, the manufacturer will list the rim widths that are compatible with a particular sized tire (5.5", 6", 6.5", etc.)
CTScott is offline
Old 04-03-2011, 08:47 AM   #3
*MAD DOG*
*MAD DOG*'s Avatar
Thanks...... I think....... not sure still.....
ps we run metric here
Old 04-03-2011, 09:41 AM   #4
Just multiply by 2.54...
Actually, pulling up an example on TireRack.com, I see that a 195/60 R15 will work on a 5.5" to 7" rim, so the simple answer to your question is: Yes a 195 is fine on a 185 spec rim.
You will increase the tire height by 12mm with a 195/60 vs a 185/60.
CTScott is offline
Old 04-03-2011, 12:16 PM   #5
rapev-8
Drives: toyota
yes u can but 195 is taller then 185 oem
rapev-8 is offline
Old 04-03-2011, 12:34 PM   #6
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
^not much.^ maybe a mm.. 195 is wider then 185
ilikerice is offline
Old 04-03-2011, 02:53 PM   #7
dingbat
Drives: '10 3D Liftback
195/60/15 is taller than 185/60/15
195/55/15 is a tiny bit shorter than 185/60/15
195/50/15 is significantly shorter than 185/60/15
May vary slightly by brand.
dingbat is offline
Old 04-03-2011, 06:16 PM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
195/60/15's will fit the stock wheels very well... and IMHO the 195/60/15 is a better fitment than the original 185/60/15.
kimona is offline
Old 04-03-2011, 09:02 PM   #9
*MAD DOG*
*MAD DOG*'s Avatar
Thanks Scott, kimona and everyone else. The guy at Goodyear said I can put 195 on the 185 rim. But recommended against it. He did state why and it did make sense at the time. It was a Yaris related thing and that is why he recommended to put the OEM size back on.
I think I've got myself a decent deal. $80 a tire including fitting and balancing. Then the front end alignment is gonna be $55. Tires are not a brand name but look like these MICHELIN XM1+
Old 04-04-2011, 03:43 AM   #10
detroiter
detroiter's Avatar
If both are 60 tall, how on earth could the 195 be 12mm bigger? I can see wider because it's 195 instead of 185..but both are 60 in height
detroiter is offline
Old 04-04-2011, 06:19 AM   #11
The "60" part is a percentage... really weird system, tires are measured in centimeters, percents and inches
Basically the actual height of the sidewall is 60% of the width of the tire (the 185/195 part).
eTiMaGo is offline
Old 04-04-2011, 11:13 PM   #12
brg88tx
Drives: 07 Yaris Sedan, Auto
op, i have 195/60r15 on my sedan. they are approx 1.98% too tall so the speedo will be slightly off and your odometer will read 1.98% too few miles.
to compute mileage you must multiply the miles driven by .0198 to come up with the actual miles before you divide by gallons used.
brg88tx is offline
Old 04-04-2011, 11:29 PM   #13
*MAD DOG*
*MAD DOG*'s Avatar
Thanks everyone for you help on this issue. But I now have 4 185 60 15 and could not be happier. Mods please close this thread.
18" TRD Rims and Pirelli Tires FS AlphaFox78 Items for Sale by private party 38 10-14-2010 01:54 PM
Rims and tires on craigslist for 350 for bay area members YarisSedan California 0 01-12-2010 02:21 AM
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 09:22 PM
Rims & Tires riceboy Items for Sale by private party 19 11-25-2006 01:22 AM
New rims - old tires littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-15-2006 07:51 PM
